You say it spins over fast so it sounds like its spinning over faster than you are used to hearing turn over.ould be that the timing belt has broken. If the timing belt breaks the motor won't have any compression and will turn over fast like all the spark plugs have been removed.Its hard to say for sure without knowing what car you have but if your oil fill cap is on the valve cover you might be able to look down inside the valve cover and see if the lifters are moving. The bad thing is some motors are interference motors and some are non interference motors which means if a motor is an interference and the timing belt breaks the pistons will bend the valves and the non interference they will not. If you register on Autozone you can go to their online repair guides to find out what motor you have. Hope this was helpful and have a great day
Hi Kenny:
Old mechanic's philosophy; If you have fuel, and you have spark, it should run. Some more info would help. Did it run before? What happened immediately before it stopped running?
What is it? Give us some hints and we'll help you get mobile. Cheerfuls.
