Toshiba SD3020KB
? worked at a electronic retailer and the manufacturer or distributor gave us the region codes and the proper way to unlock the different brands. Keep in mind there are several brands and models incapable of DVD region unlock. No matter if they are capable of changing to PAL or NTSC in DVD player settings . This upcoming DVD I believe can't be open.
SOURCE: toshiba sd270e dvd player - making it multi region please
- Power On
- Open Tray
- Press 9879 0 (0 stands for Multiregion, you may press buttons 1 to 6 to choose a specific region)
- A Message appears stating that "The Reg.No was changed to: [insert whatever region (0-6) you selected here]"
SOURCE: multi region hacks
Try this may be work
Multi-Region:
Put DVD into player - wait for regional code violation screen to appear
Once this has occurred press the M (Memory) button on your remote
Press 1 for Title 1 and Play on the remote - this will over-ride the regional code violation detection menu
You can watch the movie by pressing Fwd on remote and change chapters by using the T (Title/Chapter) button on the remote)
or
Switch On DVD player without disc in machine
Press Enter
Press 8, 4, 2, 6 and 9
Press Enter
Player should turn itself Off. If not switch it Off
Switch player back On
SOURCE: dvd hack needed for sd-kv550
hi
only just seen this post in case of still wanting the dvd code you could try here video help
just type make model in to search for dvd codes.
riz.
SOURCE: Need multi region hack code pioneer dv-220v-k
There is no need for region hack on this unit. It plays region free and all PAL dvd's out of the box without reprogram.
