SOURCE: frigidaire ice dispenser problem
The ice anger will be controlled by a motor system, the hummming could bea result of stuck rotor or the motor system is faulty. the motor might needs replacement.this will explain why the ice is not dispenced.
SOURCE: Dispenser will not dispense Ice
Sounds like the auger motor froze . Remove the ice bin and , using a hair dryer , heat the forks on the dispensor motor . This will thaw out the armature of the motor . Try pressing for ice occasionally to see if forks turn , Have to close the door or push in the lite button to test .
SOURCE: Whirlpool Gold Model GD25SFXHS03 exterior ice lever not working
Your problem is probably a broken plastic switch bracket . Pt # 2180226 . To access , use a butter knife between the dispensor grill and the lower portion of the dispensor cover . FIRST , remove the cover on the top freezer hinge , and disconnect the plug there . This removes all power to the door . Insert the knife about 1 " from the side , and push down and inward , to push the plastic tab of the cover , outward . Do the same for the other side . Lift upward to slip the top tabs free of the mount . Disconnect the plug to the dispensor cover , and remove the cover . The white piece with the 2 switches , probably has a short plastic stub , broken off which holds the ice dispensor switch . Looks like maybe 4 small screws , hold the switch bracket on . Transfer the switches carefully ,because you are working with plastic . When reinstalling the dispensor cover , after attaching the receptical , slip the top portion of the cover in place , and pop the bottom to latch the lower clips .
SOURCE: ice maker is not operating
Take it out and let it thaw. -- They can freeze up. Also, there is a gear or small wheel on the front but under a plastic cover, remove the cover and (GENTLY) help the wheel turn (usually clockwise) and you may help to free up a locked wheel that turns the rod which dispenses the ice. Careful and goood luck!! >>>don't force it or you could damage it!!
SOURCE: Ice won't come out the door
There is 2 switches in the dispenser that get energized when you push in the levers....check those out. Also there is a small control board in most refrigerators....and that could be malfunctioning.
