Printer freezes halfway through print job how do i fix this issue
Dear Sinclair
The freezing occurs due to two things.
1- when you command print file size is more than the buffer RAM of the printer. ( it will solved choosing page no. selection to print). If there is option to increase the RAM of printer, may be up graded.
2- Fixing temp. when exceeds predetermined temp. it takes a short time may be neglected.
Thanks.
Testimonial: "hi sahoo all our print files are max 512kb and the internal ram is 48megs but thanks for the info i will check the fixing unit and get back to you"
hi Sahoo i replaced the fuser unit and added new ram thanks again for the info the machine seems to be working fine!
