Question about Sharp Office Equipment & Supplies
ERROR CODE F2-40 ON SHARP AR-5618 COPIER - Sharp Office Equipment & Supplies
  • Sharp Expert
  • 263 Answers
This code comes due to any of the three reasons
1. No developer or poor developer
2. Faulty td sensor
3. Installing wrong developer
Solution
Instal developer ar235fv/dv and run developer command 25 sub 2. A number of between 120-140 should display during running period. If no number is displaying, check if the gears are moving smoothly, if yes replace td sensor.
Posted on Feb 26, 2019
    New Friend:
  • 8 Answers
Replace Toner chip ..
100% work this & do not use duplicate toner for this machine genuine toner will help you increase your machines life.
Posted on Nov 23, 2017
  • Sharp Master
  • 6,825 Answers
Using third party drum or toner replace with OEM
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jan 30, 2016
  • 190 Answers
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Posted on Jan 27, 2009
  • 126 Answers
SOURCE: sharp ar 250 copier error code CH
CH - open cover in the paper feed area
CH blinking - Dev unit is not properly installed
For the 'CH' check the covers and make sure all covers are closed properly.
For the 'Blinking CH' take the dev. Unit open and the reinstall unit properly.
Pls rate – thank you
Posted on Mar 03, 2009
007tech
  • 95 Answers
SOURCE: Sharp Copier AR -407 Error code H3-00
H3-00 means there was a problem in the fuser unit of the copier - a temperature problem. The correct temperature is not reached within a certain time.
It could be a thermostat or thermistor problem - both monitor temperature. you could remove the fuser unit and make sure these items are clean - no build up on them. there should be a center and side thermistor.
You can reset the error code in SIM mode by pressing the following keys one after the other "P" "interupt" "C" "interupt" then 14 and start/copy key. confirm if required. make sure the copier is restarted afterwards.
If the error persists then you may need new thermistors.
Hope this helps.
Posted on Apr 12, 2009
007tech
  • 95 Answers
SOURCE: sharp copier ar-bc320 error code??
the DK message means it is time to replace the black drum unit. the drum unit is called an ARC26DU. open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum unit out towards you....slide in the new drum unit.
to reset drum counter go into SIM mode by pressing the following keys one after the other "P" "*" "C" "*" then 24 and start/copy key then 7 then select the color drum you are replacing and confirm reset. make sure copier restarts afterwards
DO NOT refill these toner cartridges (even if you can find someone to do it) The toner cartridges for these machines have generally had ongoing problems as far as longevity and quality - refilling them will only make it worse.
Posted on Apr 23, 2009
  • 7 Answers
SOURCE: I have a sharp copier, model AR-285, H4-01
H4 error pertains to lamp errors.
that would either be the copy lamp or the heater lamp.
check both lamps.
with heater lamps,it's usually caused by either a broken heater lamp or a dirty thermostat on the heater roller assembly.
Posted on Jun 10, 2009
How do i clear error f2 70 on sharp ar 5618
Service Manual SHARP AR 5618 5620 5623 SME honestly I did not see this code in the owners manual but it should have a number you can call to ask how to clear it. I've noticed a few people have asked this question for this specific product but haven't gotten any answers. If you do find the solution please post it for people with the problem in the future :)
Sep 27, 2015 | Sharp Office Equipment & Supplies
F2 70 error code on sharp ar-5618, how can i resolve it.
i have sharp ar 5620n it is showing error f2-70 what might be the course
Sep 06, 2013 | Sharp AR-M277 Digital Copier Copier
F2-64 on sharp AR-5318
sharp ar 5618 zerox machine in f2 64 error solution
Aug 04, 2012 | Office Equipment & Supplies
How to reset Total counter on sharp AR-5618/5620 copier
Please give me code to increase the brightness of Sharp AR5618.
Jul 26, 2012 | Office Equipment & Supplies
Sharp AR 5618S Error F2
Hope this help.
Hold down the copy start button
You will get F2 flash then 2 numbers will flash
http://www.manualslib.com/manual/902246/Sharp-Ar-5618.html?page=55#manual
Jul 06, 2012 | Sharp Office Equipment & Supplies
Sharp ar 5618 meter reeding reset
i want to change meter reading of sharp ar5618
May 03, 2012 | Sharp Office Equipment & Supplies
2,367 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
George Mclaughlin
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
