Navman NavPix  N40i GPS Receiver Logo
C
Carolyn Strobl Posted on Mar 18, 2015
How do I update?
I am having problems trying to update.....
While connecting USB and searching for youtube it shows "initialisng...try again later"...please solve this problem...previously it was getting
Try try to update the firmware of the tv. Sometimes errors in the firmware can cause such problems. Here we have added the link to the software update for your tv offered by LG and also the user manual.Before trying to update the tv try to read the manual thoroughly, how to update the firmware.
Product Support
2answers
UPDATE
The update disk was provided with xbox when new, a download update is available.
2answers
Cant update to ios 8.2
Check if you have enough storage space, check if you are updating using weak or slow internet connection, if the problem still exist try updating using iTunes on your computer.
STATUS CODE 4099-4174-1600-0700-C000-000E
Xbox.com has a handy search page to lookup error codes:
http://support.xbox.com/en-US/error-code-lookup
From that page, those is the answer and resolution they give, good luck:
" Error C000-000E occurs when you try to download an update to your Xbox 360 console
Problem
You see the following error when you try to download an update to your Xbox 360 console:
error code xxxx-xxxx-xxxx-xxxx-C000-000E
Update failed.
Note In this error code, the "x" digits vary.
This error message means your console could not download a software update from Xbox Live.
Solutions
To resolve this problem, try the following solutions:
Solution 1: Try installing the update again.
Solution 2: If you're having problems connecting or staying connected to Xbox Live, see Troubleshoot your Xbox Live connection.
Note You can also update your console software by copying the update to a USB flash drive or a disc and then applying it to the console. "
Windows no longer updates
have you tried deleting the contents windows update directory?
( c:\Windows\SoftwareDistribution\Download )
After i reformat my laptop, no sound can be hear from it
I believe you have an audio driver problem. What you can try is to use the drivers and utilities disk that your dealer gave you when you purchased your computer unit. Install all the necessary drivers and utilities and I'm sure you will have your sound/audio back.
In case you don't have a drivers and utilities disk with you try to go to windows update using internet explorer browser. Find updates from microsoft windows update. Once the updates are found, try to check the custom updates not the priority updates. On the left side of the screen you will find a selection of updates try to click on the hardwqare(optional) updates if you find a n update on your audio device then select and install. reboot your computer after all the updates are installed and check your audio after reboot
2answers
I have a laserjet 4L (running XP SP3 and Office 7 SP2) and having problems printing - error message on the tool bar says 'document failed to print'. I have tryed restarting and unplugging the unit and...
Dear Mark, You do not need to upgrade driver but you should reset your data cable even it is parallel. After pluged again you should take a reboot and then try to print again.
Good Luck
I'm trying to update a Magellan map update on my 760
plke1691
I think your problem is that you are using XP with SP 3, you cannot use anything more than XP SP2, so find yourself a friend that have an older operating system and update it. I bet you will not have any problem
Auto Nav 2000 aka GPS4ME
3answers
No Audio Output Device is Installed
the Solution to your problem is that your Laptop need an Audio Driver to drive the Sound card on your system. i Suggest you contact your hard ware vendor for the latest sound driver
3answers
USB
yes what is the usb device and the os
Top Navman GPS Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Mike Cairns
Mike Cairns
Are you a Navman GPS Expert? Answer questions, earn points and help others
