U need to reset security system (pass lock II). Turn key to on right b4 cranking but don't start and let security light flash for about 10-12 mins until it stops and then turn key back off, repeat procedure two more times don't actually turn key far enough to start during first two 10-12 min cycles, third cycle though after flashing stops turn the rest of the way forward for it to start. This should then reset security and solve problem sometimes only takes two cycles to reset. Good luck, hope this is helpful & solves problem.
i had tjis problem it is a security tking the car simply does not recognize your key thinks someone trying to steal solution turn key all the way to on as if starting let go wait 10 min when security light stops flashing and is steady turn key to off then restart note you have to wait the full 10 min if you dont car will not reset security and you will have to start over
THERE IS A CHIP IN THE KEY I BELIEVE. THERE IS A RELEARN PROCEDURE YOU CAN TRY IF WHEN YOU TRY AND START IT THE SECURITY LIGHT FLASHES. HOOK UP A BATTERY CHARGER. TURN THE KEY ON AND TRY AND START THE CAR AND RELEASE . DO NOT TURN KEY OFF LEAVE IT IN THE RUN POSITION. AFTER 10 MINS THE LIGHT WILL STOP FLASHING. TURN KEY OFF. TRY AND RESTART CAR AND AGAIN DO NOT TURN KEY OFF LEAVE IN THE RUN POSITION. LET SET 10 MINS AGAIN. LIGHT WILL STOP FLASHING AFTER THAT 10 MINS. DO IT AGAIN FOR THE 3RD TIME. SHUT KEY OFF LET SET 5 SECONDS AND START THE VEHICLE. HOPE THIS HELPS
Since the parts are no longer avail for this car to fix this issue more than likely why not just bypass the security system altogether. Here is how you do that. Click HERE
turn ignition switch on but don,t try to start the security light should be flashing walk away from vehicle and let sit for 10 to 15 mins. the security ligjht should stop flashing start car now you are done hope this helps
ok you need to re-learn your passlock. to do this. turn the key all the way to start and leave it on. you will then see the passlock light flashing. let it sit for 10 mins. or until the light stops flashing. then turn the key off and take it out for 30 secs. repeat this 2 more times. after the last 10 min cycle when the light stops flashing. take the key out for at least 1 min. now try to crank the vehc. that should solve your problem. have a great day!
