Micro switch is not operated correctly
If you remove the coffee outlet, you will see a little tab sticking out of it which inserts into the machine just above all the outlet pipes. this "tab" locates onto a micro switch. After a period of time the outlet can become misshaped(not noticeably ). if you squeeze the outlet gently it will temporarily fix it. the outlet will need to be replaced eventually and or the outlet holder.
