Prewash light flashing and pump constantly running, have switched machine off to try and reset, checked filters and hoses everthing looks fine. Fault happened at the begining of normal wash programme.Prewash light flashing and pump constantly running, have switched machine off to try and reset, checked filters and hoses everthing looks fine. Fault happened at the begining of normal wash programme.
AnonymousOct 01, 2008
when i switch on the pre-wash lights constantly flashes and sounds if its constantly running the pump to empty water...
It's staying in pre-wash mode each time I turn on the dishwasher. I can hear it emptying but the cycle fails to start, it remains in pre-wash. It's staying in pre-wash mode each time I turn on the dishwasher. I can hear it emptying but the cycle fails to start, it remains in pre-wash.
You can't post conmments that contain an email address.
1.press cancel button
2.check if the door closes securely.
3.since there is water in d/w try running a short cycle.If it works, clean the inside thoroughly to ensure no clogs.
Flashing lights, pump running even when turned off. Had to switch off at the socket. The vibration from the machine had managed to give a quarter turn to the appliance gate valve, the type with the little blue handle. I could see the indentation in the rear rubber panel on the back of the dishwasher. Unscrewed the little blue handle, pushed the machine back in and started working as normal. :)
Try unplugging it and plugging it in again - that might reset the unit. And find an online operator's manual and see if there is information that will guide you - they are usually a free download from manufacturer's website.
My Diplomat ADP8352 when running a cycle it will run for ages, doesn't seem to get hot. If i switch off the m/c then switch it on again it dumps the water left in the m/c?
Here are the eco related error codes for your washer.. 1)Light 3 (eco) flashes. Water is present in the flood catching tray at
the bottom which usually indicates that there is a leak somewhere. More
often than not this is just a pipe with a poor fitting and simply
tightening the clip is enough to stop the leak. Our machine had a very
slow leak from one pipe (not enough to trigger the alarm) which was
fixed in this way. The leak is detected by a small float switch located
in the flood catch tray.
Undo 4 screws on the metal plate under the dishwasher 3 at the front 1
at the back, this reveals The pump check the seals are in place on the
waste pump.
2)
Wash indicator lights 3 + 5 (eco + pre) flashing rapidly. Filter is clogged. Pull out the filter and clean it. 3)Runs for approx. 3 minutes and then stops. Lights 3 + 4 (eco and fast)
flash. Probably caused by being plumbed into a hot rather than cold
water supply. The incoming water is hotter than required for the wash
which causes the machine to cut out. Plumbing the machine into a cold
water supply will fix the problem with no apparent long term problems.
check the base of the machine and see if it has water in it. if so, this will cause the dishwawsher to pump out all the time. mop out and it shoiuld run. you have a leak and will have to trace it - not always easy
