check and clean the Primary Charge unit or check all the door actuator check if there is damage .it couldbe the laser gate is not opening because the (door)actuator is broken
This is the only Blu-ray player that can be made region-free.You will need a professional and fully programmable service remote, like Harmony or a Palm or PDA that can support Omniremote software.The procedure may look complicate if you have not done anything similar before. You will have to reprogram the remote using a PDA or a computer. Print this out and follow instructions here. For example using OmniRemote™Pro V2.01 and a Palm 1. Install the OmniRemote on the Palm, or PDA. 2. Copy the current Category to the Palm memo pad 3. Modify the "Button name-0" data with the following code: 0000 0067 0000 0044 0155 00ac 0015 0040 0015 0040 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0040 0015 0040 0015 0015 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0015 0015 0015 0015 0040 0015 0040 0015 0015 0015 0404 0155 00ac 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0404 4. Import the database in omniremote 5. Turn on the DVD Player. Press newly programmed 0 button on the palm. The Palm will control the DVD, and the DVD Player will turn off and on again. On restart it will be region free.
aha and your printer is not functioning right now isnt it, or it is still operational, either way that error must be solve or you will never use your printer. this error means that your pump motor is near end about 5% of its life is left. here is the sure solution for your prob. turn off your printer then press the left, down arrow and enter simultaneously then power on the printer. inside initialize the sponge and cleaner then turn off and on your printer. note: you will have to replace your pump cap assy. if it is already poor in cleaning otherwise your printhead will suffer.
