Amazon Kindle 3G Logo
A
Anonymous Posted on Mar 17, 2015
Kindle will not charge
My kindle will not charge even when plugged into a wall socket
Won't turn on and I have charged it.
Is the rechargeable battery pack still good? If it's more than 2 years old, get a new battery pack. Try using a wall socket adapter for your Kindle first and you'll know for certain.
Can I charge my Kindle fire HD 8.9 from a wall socket with the conveter I used on my kidle keyboard?
Hi Anon, If the Keyboard uses a standard microUSB charging socket,
then the answer is yes since that is what your tablet uses.
Kindle wont charge
Not all computer USB ports put out enough current to charge batteries. Try another port on the computer, if there is one. If you're going through a USB hub, remove it and connect the Kindle directly to the computer. If you have access to an AC-USB charger (one that plugs into a wall outlet instead of a computer), try using that.
2answers
After charging my lindle on my laptop i cant switch it on
Try charging it with the electrical wall plug-in.
I read in some Kindle reviews on Amazon that charging through USB ports on a computer doesn't always work.
Did you get a green light that indicated the battery was fully charged?
How do i charge my kindle comes on screen battery flat
You kindle should have come with a usb cable (one end is different from the normal usb on things like pen drives) and also a little plug with a usb port on it. If you plug these two together, then plug the other end of the cable into the kindle, once you plug the actual plug into the wall, your kindle should start to charge (you can see this by a light appearing on the bottom of the device). You can also plug this cable straight from your kindle to the computer. This will also charge it (though slower than through the mains).
My amazon kindle is unreponstive.how can I fix it, has blank screen will not let me connect to internet
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device.
My kindle reader will not power on
Make sure that the kindle is fully charged. When plugged into the wall the yellow led will light up as it is charging. When it turns green, it means the kindle is fully charged.
1helpful
2answers
My kindle has frozen
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device. If the device still does not turn on, hold the power switch for 15 seconds, this will reboot the device.
3helpful
Kindle 3g screen is blank can get it back on
Top Amazon Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Jennifer Rock
Jennifer Rock
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
