A/C turns on and off - but the fan will not run.
I would tap on the motor first ( it is on the driver's side below/behind glove box).
If it doesn't start, I would tap on the relay which controls the fan. I can't remember if it is by the motor, or over on drivers side (next to fuse panel - but you wont' have a nice little panel to remove). If you turn on/off the AC, the relay should make a clicking noise.
Next step, remove the fan motor (only a few mounting screws/bolts and air connection. Then run some wires from the car battery to the fan to see if it works. Be careful, it is only 12 volts, but a car battery can put out some serious amps. Don't attempt if you don't have basic electrical skills.
If the fan works you know it is something else - probably the relay if you didn't confirm it is good. I had to replace several relays in my 94 max, maybe 1 in the 00 max, and the 02 has needed any yet.
Needs a new motor
