Samsung Rv511 Logo
A
Anonymous Posted on Mar 17, 2015
Will i lose my emails if i reset myRV511 To factory settings
Terry Hair
Level 3:
  • Samsung Master 4,134 Answers
  • Posted on Mar 17, 2015
Terry Hair
Samsung Master
Level 3:
Answers
4134
Questions
Helped
1090270
Points
16804
That depends. If you are using a web-based email service like Yahoo! or Google Gmail where you access your emails from your web browser, then the answer is no, anything on the website will still be there when you return there to sign on again. However, if you use Outlook to download you emails to your PC and then delete them from the webserver, you WILL lose them if you reset. Also, anything that you copied down from the server to the PC and stored will be lost. Remember, if it is inside the box (PC), color it gone. If it is in the cloud (on the web), it's OK.
My Samsung schm828 c I have forgot my password and email account cuz I had lost the phone for a little bit but it just keeps saying too many attempts on the screen and that's all it'll do
If you have forgotten the password and email account associated with your Samsung SCH-M828C phone, and you have attempted to enter the password too many times, the device may be temporarily locked for security reasons. In this case, you may need to perform a factory reset on your phone to regain access to it.
Please note that performing a factory reset will erase all data on your phone, so you will lose any personal information, contacts, messages, and files stored on the device. However, this is usually the only way to unlock a device that has been locked due to too many password attempts.
To perform a factory reset on your Samsung SCH-M828C phone, follow these steps:
  1. Turn off your phone.
  2. Press and hold the Volume Up, Home, and Power buttons at the same time.
  3. Release the buttons when the Samsung logo appears on the screen.
  4. Use the Volume Up and Down buttons to navigate to the "wipe data/factory reset" option, and then press the Power button to select it.
  5. Select "Yes - delete all user data" to confirm the reset.
  6. Once the reset is complete, select the "reboot system now" option to restart your phone.
After the reset is complete, your phone should be unlocked and you can set up a new Google account and password
I got locked out of my kurio
If the tablet is connected to the internet, tap on forgot password or pattern then enter gmail account to receive an email with the correct password/pattern you set.
Below are steps to recover from being locked out. The first is the most extreme. The second is less extreme. And the third is probably the preferred method.
Firs, t the extreme reset. You lose your data but it returns it to factory default condition, i. e. right out of the box.
Kurio Extreme 2 Factory Reset
Secondly, the soft reset.
Kurio How to Perform Soft Reset
Thirdly, a Kurio password reset:
Kurio Password Reset Kurio 4S Kurio 7S Kurio 10S
How to syart over again i have seberal accoumts i fimd?
go to settings click on accounts open each mail account go to bottom click settings and that will give you the option you need but if you want to start again do a factory reset but you lose all your info music books the loot best option is settings , Accounts your accounts pop up then click on each one then you have a choice but every email you remove you lose info stord on it but you can always reconnect when you need to.
How do you factory reset ZTE Whirl 2 forgot pattern on home screen and forgot password
Pull the battery out then reinsert it. Now hold the power button and volume down simultaneously until it boots to android recovery screen. Select "Reset to factory defaults" then "Yes". (Press Volume Up or Down to navigate and Power Button to select).
It takes some time to reboot. You have to re-setup google accounts, settings and apps.
[Warning: You Will Lose Your Email, Pictures, Messages, Files and Personal Data In This Process]
2answers
How do I reset tv
If you can get into settings you may find factory default.
3helpful
2answers
How to restore Dell 1550 Inspiron to actual factory setting
Unless your using a email program such as thunder bird or if it is a Yahoo or Gmail account I would not even worry about having to delete anything. Just send it back they cannot access private information without the password anyway. So send it back get it fixed and move forward with a new machine when it comes back? John
How to reset Dell PC E521 to original factory settings. Will I lose my email?
You need to use your system restore disk, or Use the "recovery disk" options is on the partitioned Hard drive.
If you are using the CD recovery Disk,
1. Turn your computer off
2. Turn on and when you see the white bar loading for the dell bios, press F12 or whichever the option is for one-time boot menu.
3. Select the drive that specifies your cd-drive.
Resetting your System OS back to default settings will erased all your previous Settings & Data too!!
Backup all your important data before restoring back to the default factory settings.
Hope it helps.
3answers
Hard Reset
To do a Hard Factory Reset:
Simultaneously press the Suspend/Resume (END) button whilst pressing the stylus tip into the reset opening.
end_button.jpg reset_button.jpg Keep them held until the screen comes back on. Then release the buttons
You will get the Boot options:
  • CLEAN REGISTRY - This resets the device to factory settings, losing applications but keeps the data intact.
  • FACTORY DEFAULTS - This completely wipes everything and resets the device back to it's factory defaults.
  • SKIP
    Try Clean Registry first.
  • Not finding what you are looking for?
    Top Samsung Computers & Internet Experts
    ZJ Limited
    ZJ Limited
    Grand Canyon Tech
    Grand Canyon Tech
    Jean Thiebaux
    Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
