Aastra Telecom 9116 Corded Phone Logo
Posted on Jul 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Phone does not ring just flashes - Aastra Telecom 9116 Corded Phone
Anonymous
Level 2:
Sergeant:
  • Expert 277 Answers
  • Posted on Jul 09, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
277
Questions
0
Helped
77626
Points
755
Sheck the settings by going to ringtones and increase the volume,if persist then unscrew the phone and check the ringer if faulty repair, if damage replase it with the aim of soldering iron,soldering led and reading metre
My Samsung iDCS 18D phone will not ring. The Line light flashes, and I can asnwer calls, but it won't ring. I have tried adjusting volume levels, etc- but it seems like the ringer is turned off.
First prove it is not a faulty handset. Find someone elses phone that is the same model as yours and rings then plug it into your line. If that phone rings your handset is faulty. If the borrowed phone will not ring but flashes then it is programming
How do I turn the ringer off at my phone for external incoming calls?
Go into the extension programming and change the line settings to no ring. It is best done if you have a display phone so you can see the changes. If not, then you will need to look at the flashing line lights when you enter the programming mode.
Press Feature 00. This will take you into the programming mode. You should see the line buttons lit up green. They will be Solid (Immediate Ring) or Slow Flash (Delayed Ring) or Fast Flash (No Ring). I assume yours is solid so push each line button until it changes to a fast flash. Once done press Feature 00 to exit the system and save the settings.
3helpful
How Do I for some of my lines only to ring on certain phones? I dont want the rest of my phones to ring.
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Central telephone Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Press feature "00" to logout
5helpful
2answers
Hello.. We have the parter-18D phone system. one of the phone rings when there is an incoming call, but it shouldn't, since this is not the main phone Ext 10. How can I program this phone to ring only...
Press the right hand intercom once. The display should say Centralized Programming.
5helpful
Ring options
1helpful
Phone flashes but no volume for 4 rings on incomming call
The phone has to be a member of an ICD group and have the ring set to immediate. Since this is a SYSTEM program, I don't think you can change it without the assistance of a programmer.
If you somehow have access, it's changed in programs 620-622. You need to know which group is assigned, usually group 1 put you can find that in 622. Members are set in 620 and the ring delays are in 621.
Carl
1helpful
Line ringing on different phones
Im guessing by Lucent 308 you mean Lucent Partner ACS. Changing ringing on a Partner system is done on either ext 10 or 11.
Hope that helps
1helpful
Change ringer tone
Message/Ringer Lamp: The Message/
Ringer lamp informs you visually that you
have a message or a call.
When you receive a call, the lamp
flashes depending on the ringing pattern.
When the ringing pattern is set to Single
(Slow flash), Double (Moderate flash), or
Triple (Rapid flash) in your PBX, the lamp
flashes. When the other ringing patterns
are set in your PBX, the lamp may not
flash. (e.g., S-Double, Call Waiting
Tone1).
When someone has left you a message,
the lamp is lit continuously.
Please note that the above indicates that ring patterns are set in the the PBX. These are issues that require a real person to sit at the main system and program the features that users need. I hope you have an I.T. person that knows your phone system. If you don't, you'll have to find a communications company in your area that can program your system. Thanks for using Fixya.
1helpful
Phone won't ring. The arrow will flash but no ring. Meridian 7310
you can try to plug it in at a set that does ring and make sure it wokrs there. The programming should not have changed with the phone but ... anything is possible. If it rings at the other location then it will be the programming for that extension. Also check that it is not in DND do not disturb
2helpful
2answers
Lucent Partner 18D - stop ringing of line 2 at phone
From extension 10 or 11
Press feature 00
Left intercom
Left intercom
right intercom
enter your extension number
all lines that are programmed on your phone will light up.
Solid means immediate ring. Slow flash means delayed ring. Really fast flash means no ring.
Press the line you wish to not ring, 2 times.
Feature 00 when you are done.
Top Aastra Telecom Lands Phones Experts
k24674
Are you an Aastra Telecom Lands Phone Expert? Answer questions, earn points and help others
