Kyocera Mita KM-2050 Printer Logo
A
Anonymous Posted on Mar 17, 2015
How to connect km 2050 machine to pc through cable
Xerox machine
  • Brian Hytt
    Brian Hytt Dec 29, 2018
    I need drivers for an unspecified printer OEM 2DA-20. The printer name is a Kyocera km 2050.
Gil Shultz
Level 3:
  • Kyocera Mita Master 3,464 Answers
  • Posted on Apr 02, 2015
Gil Shultz
Kyocera Mita Master
Level 3:
Answers
3464
Questions
Helped
731015
Points
11104
Just get a cable that matches both ends and plug them in. If it is a network then get a crossover cable otherwise it will not connect. A crossover cable swaps 1&2 3&6
Doug Sneddon
Level 2:
New Friend:
  • Expert 60 Answers
Doug Sneddon
Expert
Level 2:
New Friend:
Answers
60
Questions
0
Helped
81259
Points
108
What cable usb or network cable
4 Related Answers
Anonymous
  • 51 Answers
  • Posted on Feb 17, 2009
SOURCE: How do I install a KM-2050 wireless connection on my computer
1. need to get the IP address of the printer, print a configuration page from the printer and that should have it on it
2. open up the add a printer wizard and for the port you need to create a new tcp/ip port with the ip address of the printer
3. you need to have the drivers available on your computer to complete the addition of the printer
let me know if you need clarification on any of these steps
Anonymous
  • Posted on Mar 12, 2009
SOURCE: kyocera km-2050 scanning function
The km 2050 was on network, but moved to home and directly into tower system via usb interface connector. Printer works, but can not get scanner to work? read instructions without a clue. can someone help with correct proceedure?
Anonymous
  • 622 Answers
  • Posted on Dec 24, 2009
SOURCE: Kyocera KM-2050 network trouble
check the ip address, subnet, and gateway on your printer... by going to print and then print status page...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Anonymous
  • 62 Answers
  • Posted on Feb 01, 2010
SOURCE: Printing problems Kyocera KM 2050
when this error comes up..hit the print button on the left hand side..this will than tell you on the screen wha the actual problem is..i.e ( out of paper...lost connection etc
Kyocera KM-2050 DIRTY COPIES BOTH SIDES.
Clean the feed rollers. Don't use refilled toner cartridges. Brand new OEM toner every time.
KM-2050 dirty on back of copies
Copytechnet https://www.copytechnet.com > kyocera-mita-copystar
Mar 27, 2009 - toner scatter on back of copies. I've noticed a bit of toner build up just below the drum and also a slight bit on the transfer roller. I wiped ...
KM 2050 Copying half of the page!!!!! - Copytechnet
Sep 9, 2014
KM-1650 & KM-2050 - image compression - Copytechnet
Dec 14, 2011
kyocera mita km2050 dirty toner at the back of paper
Sep 25, 2020
Miscellaneous KM-5050 faint copies. - Copytechnet
Jun 3, 2015
More results from www.copytechnet.com
Kyosera km 2050 error code co180 display
Machine number mismatch
Machine number of main and
engine does not match.problem is Data damage of
EEPROM.
KM 2050 NOT TURN ON
Back to basics, have you tried a different power point and mains cable?
If still dead the this would indicate a blown fuse on the power supply or faulty on/off switch.
10helpful
2answers
KM-2050 Printer: i need to find the pin number to my kyocera km-205...
I need to create a new pin on kyocera 5050 machine as the old one is lost
1helpful
MY PC DON'T DETECT THE SCANNER FROM A KYOCERA 2050
First make sure you have a scanner on this machie. The scanner NIC is an option for this machine. If you press the Scanner button on the panel and nothing happens then you most likely don't have one. There is a network connection for printing that is standard that is located on the right side of the machine. If you have a scanner on the machine there will be a second network connection about 6 inch above the printer network connection. It sounds like you don't have the scan option.
1helpful
Driver
From links below you can download driver and manual:
KM-2050 driver KM-2050 utility KM-2050 datasheet KM-2050 installation manual KM-2050 user manual
KM-2050 documentation
Do not forget to rate the solution.
Thanks
Top Kyocera Mita Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Ngoro
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
