Sounds like plumbing problem
http://waterheatertimer.org/Crossover.html
SOURCE: Reliance gas water heater 40 capicity, has a leak on the top
Most likely only one of the pipes is leaking but weaping enough to cover the top and indented places near both inlet and outlet. This leak has most likely penetrated all the insulation and is a problem throughout the tank wrap insulation...If you are able to blow air continuously long enough to determine which connection is leaking then fix it. It will likely to take quite a while to dry out all the insulation if the water has migrated down into the tank wrap... If you determine that the insulation is waterlogged, you may be able to drill several small holes in the external cover.
good luck
SOURCE: i have a richmond gas hot water heater model
resetting your lock out for richmond power vent
SOURCE: Natural gas hot water heater not stying lit
Probably a bad solenoid in the gas valve. Higher voltage of a new thermocouple keeps it open longer but it still fails over a period of time. Look into a new gas valve for the water heater.
SOURCE: need to empty reliance 501 hot water heater how?
1) Shut the breaker off to it at the panel. 2) Hook a hose up to it (the bottom has a drain). 3) Close the valve to the water heater (on the cold water supply). 4) Open drain on the bottom of water heater. 5) Open the relief valve to allow air into the tank (it won't drain otherwise - think if you put your finger on one end of a straw - the liquid stays in until you let go). Why are you draining it by the way?
