This vehicle should have 2 flasher relays one that operates the emergency flashers and one operating the turn signals.Easiest way to locate these would be to turn the emergency flashers on and listen to where the clicking is coming from usually the flasher are pretty close to each other.Once you find the flasher unit you can swap the flasher unit that is working with the one that is not and if the turn signals work after that you will need to purchase another flasher relay.
Sounds like the turn signal flasher is going bad. The easy way to find wher the flasher is hidden is turn the turn signal on and find the clicking, that is the flasher. The emergency flashers work fine because they use a different flasher.
If neither the emerg. flashers nor turn signal work then it's the relay will cost $25-$30. the relay is all part of the emerg. flasher button. be very careful popping it out so you don't ruin the finish on the dash. remove one of the cover plates just below it will make it a little easier. good luck
did you replace the turn signal flasher or the emergency flasher? turn on the emergency flasher lights and pull that flasher if they quit working you changed the wrong one.
There a two modules 1 for the turn signals and 1 for the flashers. Look under your dash around the steering wheel and fuse box area for one that is in the wiring harness.
Sounds like a multifunction switch, work the emergency flasher button up and down a few times, then attempt to work the turn signals if the signals work then you will need a multifunction switch.
