If your washing machine shakes violently or if there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Hi, The inner bearing will be faulty kindly replace the inner bearings as well as water seal before that kindly check whether the drum is freely moving with out any shaking If you find any shaking means you are suppose to change the drum only
have you tightened the jamb nuts on the legs after leveling the machine so they can't move from where you set them initially when you leveled the unit?
There are 2 shock absorbers/springs attached to the drum. If one of them breaks it will cause a loud banging noise when you wash heavy loads. This is an easy fix. The part is about $22.00 and it is accessed throught the front bottom panel.
you could have a broken shock but most of the time the spider gear is gone,the money it costs to fix it you could by a new washer,that will be up to you to decide
very loud in spin cycle can mean a bad rear bearing, not something a homeowner would want to try to replace, parts would exceed 6-7 hundered dollars. you may have some extended part warr through the manufacture. still probly gonna be a 5 hundred when the labor is added in
Most noises
from a washing machine occur during the spin cycle. If you hear loud
thumping during the spin, the load of clothes may have become
unbalanced. Stop the washer and redistribute the clothes, then re-start
