Callaway Golf X Hot Pro Drivers Logo
P
Pierce Butler Posted on Mar 16, 2015
How do you set up the club for a draw ? - Callaway Golf X Hot Pro Drivers
I'm having trouble with opening .plt files in my 4d qbot software. What do I need to do to make the software open the files?
Art & Stitch
http://www.artnstitch.com/
Online Classes - Art & Stitch Club - http://myqbot.com/clubs/info_ArtAndStitch.html
Tutorials by LiTen Up Technologies, http://myqbot.com/clubs/info_tutorial_ArtAndStitch.html
Tutorials by Loes and Theo, http://www.artnstitch.com/tutorials.htm
Corel Draw
http://www.corel.com/corel/
Tutorials - http://www.corel.com/corel/pages/index.jsp?pgid=12300114#all1
Creative Drawings
http://www.creative-drawings.com/index.php/creativeDRAWings/
Learning Center - http://www.creative-drawings.com/index.php/learningCenter/
Floriani
http://www.florianisoftware.com/
4D QBOT - no longer available
http://www.emnetsoftware.eu/videos/4DQBOT/QBOT_Overview/index.html
4D QuiltDesign Creator - Upgrade from 4D QuiltDesign Creator no longer available
http://www.youtube.com/watch?v=n78zcAwgans
5D QuiltDesign Creator -- Upgrade from 4D QuiltDesign Creator or sold seperatly
http://www.5dquiltdesign.com/
Learning Center - http://www.5dlearningcenter.com/QuiltDesign/
There may be other programs available. These are the programs that I know, teach or use.
We also offer recorded Webinars for sale at www.myQBOT.com.
http://myqbot.com/pages/videos_chpg.html
http://myqbot.com/pages/videos_swf.html
Happy Quilting
What is the difference between N and NU in the setup of my r9 taylormade driver
From the link below:
Locking the head back in place with the torque wrench supplied free with the club, gives me four main settings to set up the trajectory:
*Towards L sets the club to give a maximum draw (presumably for those with a built slice or fade swing).
*Towards R sets the club for a controlled fade (for those who consistently over draw or pull tee shots)
*Neutral Upright (NU) delivers a slight draw (for those with a tendency toward a slight fade)
* Neutral (N) produces a slight fade (my preferred setting to counteract an occasional hook/pull)
Long term test TaylorMade R9 driver
1helpful
I like to draw a contitution for my sport club but has no idea to to it ,can you help me
To start your Constitution,,I found some articles for you to go over with the club members. http://clubsonline.dsr.wa.gov.au/assets/files/clubhouse/12%20establishing%20your%20club%20constitution%202011%20press.pdf
7helpful
I bought an r9 supertri driver and need the manual for it. any ideas?
Movable Weight Technology TM, is discretionary clubhead weight that can be easily redistributed by the player to change the characteristics of the club. By moving differently weighted cartridges, using a proprietary TaylorMade wrench, into strategically positioned ports, CG location can be optimized per golfer. Positioning more weight in the heel and less in the toe, speeds club head rotation during the forwardswing, which promotes a draw and/or reduces a slice.
Here is a link that will definately help you with the adjustment aspects of your club:
http://www.taylormadegolf.com/mainlevel/golfshop/drivers/R9-SUPERTRI.html#30
Blower doesn't work.
SOUNDS LIKE A FAULTY HEATER RESISTOR..LOCATED UNDER DASH ON PASSENGER SIDE..PICK UP A NEW ONE..EVEN FAIRLY CHEAP FROM DEALER..YOU MAY HAVE TO TRIM OPENING WITH AN UTILITY KNIFE TO GET NEW ONE IN..FAIRLY COMMON PROBLEM..THE WIRING CONNECTOR TO IT MAY BE DAMAGED ALSO..MELTED FROM EXCESSIVE CURRENT DRAW..YOU MIGHT NEED A BLOWER MOTOR AS WELL..MAY CAUSE CONNECTOR/RESISTOR DAMAGE
2answers
How to adjust the r7 fron straight, draw or slice? if I want a do
The bad think about golf clubs is they're made a certain way at the factory and it's pretty hard to change them. Forged irons hosels can be bend to change loft and lie but woods are pretty much the way you buy them. To change from slice to hook or visa versa you have to toe the face in or out and you can accomplish this by yourself just rotating your grip on the club to turn it in or out but when you do that you change the level of the sole of the club and you also change the pitch of the club face. If you want that kind of customization you need to take that into account when you purchase the club and buy what you need rather than try to change it later.
1helpful
Alarm deactivate/battery drains
its more than that all of a sudden thats not it... parasatic electrical draw could come from alternator ..yes while not running.. google parasatic draw ...
2helpful
Need manual with the schematics for the wiring of a club cart. Can't go forward and there is prob a wire loose. do not have a owners manual with cart. we've had this situation before but only with the...
Need to know what year the club car is. No drawings are in the owner's manual and there are no free service manuals available.
But all is not lost, try buggiesunlimited website for downloadable wiring diagrams. If you still have problems I can maybe help lead you through some trouble shooting steps. email is [email protected]
2answers
92 Dakota Club Cab v8 battery keeps dying?
Turn everything off,remove the key, then with a test light check the fuses. You will need to check the interer light is off. This should lead you to the trouble. Also if it has a alarm, this will **** away power too! Frankster016
Top Callaway Golf Golf Experts
Kardoc
ADMIN Andrew
ADMIN Andrew
vince
Are you a Callaway Golf Golf Expert? Answer questions, earn points and help others
