Cell Phones Logo
A
Anonymous Posted on Mar 16, 2015
Motorola bluetooth phone will not pair with jbl charge 2 wireless speaker.
Blue tooth will not pair with jbl charge 2
  • Official Brand Answer 3,100 Answers
  • Posted on Mar 16, 2015
Motorola Mobility
Level 0:
Answers
3100
Questions
Helped
685017
Points
13487
What model phone? Have you gone to JBLs website for troubleshooting?
Mark
Motorola Support
JBL Charge 2 stopped wifi connecting to pc
Problem connecting Windows 8.1 pc to JBL Charge bluetooth speaker ...
answers.microsoft.com/.../windows/.../windows8...connecting-windows...
When I try to connect the pc through Bluetooth to the above wireless speaker ... 2) What is the model of the JBL Charge Bluetooth speaker? ..... I am already able to play music from my iPhone 5 on this speaker via Bluetooth with no problems.
Cannot connect JBL Charge Bluetooth - Networking, Internet ...
en.community.dell.com/support.../network...wireless/f/.../t/19525571
Dell
Sep 22, 2013 - 16 posts - ‎11 authors
23 Replies; 16 Subscribers; Postedover 2 years ago ... I'm trying to connect my JBL Charge Speaker bluetooth with my Dell Studio 15 laptop to listen .... I am having the same problem, did you find a fix for this? ... not support audio output, then you need to add a Bluetooth adapter which includes a CD driver.
JBL Charge 2 ' Portable Bluetooth Speaker with USB Charger
www.jbl.com > Wireless > Portable Bluetooth Speakers
JBL
Rating: 4.3 - ‎110 reviews
Most popular JBL Charge 2 wireless portable speaker can charge any devices via USB... You can easily connect Charge 2 to any Bluetooth-enabled device by giving the portable's ..... Charge with proper charger or a USB port form computer.
Iphone6 states "connected" to JBL Charge but no sound. Worked fine up until a few days ago. Both show paired.
Are they connected or paired now? Make sure you don't have any other device near that may have Bluetooth on. Like a laptop, PC,or tablet. Try forgetting the device, and reconnecting. If this fails make sure your phone isn't on wifi and cellular. If this all fails. I imagine its not the fault of your transmitter, but lies in the fault of your reciever, the JBL flip. Also, is it fully charged and is the speaker holding a charge? I'm a small Bluetooth speaker junkie, and I'm sorry but I am not impressed with these at all. There are much cheaper, and better made out there, than this one.
2answers
JBL Flip blinking red and blue
This indicates that the Blue tooth pairing with the already paired device has been reset and the JBL Flip is ready for pairing with new device. This position, red and blue blinking, can be obtained by long pressing the power buton.
5helpful
2answers
My iPad won't find my Bluetooth speaker
Go to settings, General, blue tooth and remove any "other" previous paired BT devices & Turn off BT, then go to Sett. General, scroll down to reset and reset network settings, this will not delete anything. Power off BT speaker. after iPad re-boots turn on BT Speaker First, make sure BT is off on iPad as well as WIFI-wait like 10-15 seconds and then turn BT on in iPad it should see your speaker now and let you pair it up.
1helpful
Need password to connect to my phone. Motorola bluetooth H371
Hi,it all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hope it helps..
Thanks for using fixya...
Unable to use new h500 headset
The H500 is a monaural headset, thus good for phone calls only, not for listening to stereo music. You haven't specified which Motorola phone you own. Check in its user guide if it is able to handle stereo bluetooth headsets (i.e. if it bears the A2DP and AVRCP bluetooth profiles), which are suitable for music streams. If your phone is able to handle them, go to the mall (or store, or even online), buy one set which suits you better, pair them with your phone and enjoy!
Just my 2 cents... Carlos
How can I listen to music from my LG ENV 3 Using the Motorola H71
Your blue tooth does not have that capability .I check myself google motorola h710 bluetooth
6helpful
Old phone quit and blue tooth won't pair with new phone
Hold the volume buttons on the side while holding the call button for 10 seconds. It will reset the bluetooth and remove any other devices it may have been paired to. Then turn it off, back on and it will eventually stay lit blue and then you need to set it up through your phone. I hope this helps, I had the same problem and mine is working fine!
3helpful
3answers
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Top Motorola Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
