Installed on 2011 Sante Fa
SOURCE: My Mustang Cobra has a Viper alarm system that won't set
Under the dash, Your installer that worked on your Cobra should have put an valet button under the dash, It is a small round Black button, Ok with the driver door open,,put your key in the ignition and go to the on position, Locate the black button before you do this, once the ignition is on hold the black button down for 3 seconds hit it once more and then turn the ignition off, the light should start flashing again and the chirp for arm and disarm with work again, What you have going on is called Valet mode which is designed to put the alarm side of the system to sleep which can happen from accidentally bumping it.
Hope this was helpful.
That Crazy Install Guy.
SOURCE: Viper 5101 Manual Transmission - can't start
First off, is it in neutral? It can't engage the starter motor if it's in gear. Secondly, If it was professionally installed, why not just take it back and demand that they fix it?
Your wiring should somewhat match this.
SOURCE: I have had the Viper
I am trying to locate this manual for you, did you install the alarm yourself? Most places that install them will reconfigure them for free if you ever have a problem even if it's years later. The new fuel pump is not configured with the alarm properly... Do you know was it the exact same model fuel pump they put in? Or a third party fuel pump....
Tim
SOURCE: I recently purchased a used Dodge Durango. It has
I would start with checking the antenna. It should be mounted on the windshield probably at the top in the middle. Check the antenna wiring and make sure it is not all bundles up it should be wrapped in a large circle for better range. My guess would be that the antenna isnt working properly. It could even possibly be the battery in the remote or the remote itself.
SOURCE: Viper Remote Start wont work properly
if it cranks and wont start then its probably the bypass the module thats not working correctly
