Remove the battery and plug in the AC adapter. If you can not power on the laptop, your AC adapter has gone bad on you and will need to be replaced.
If it will turn on with the AC adapter, place the battery while the
laptop is on. See if it registers the battery as charging in the task
bar. If not, there may be something wrong with the battery or the
components connecting to the battery within the laptop.
Also you can below steps to check:
1) take the battery out of
your laptop and the laptop charger
2) plug your laptop charger in your laptop without the battery in it,
3) Try to turn it on the normal way:
If it turns on, then your battery has gone, (Its drained and run out of use like all batteries do)
if it stays off then its a charger problem
You would want to hope its a charger problem as they are cheap and easily replaceable
Hope i helped
I guess its a charger problem because its not turning on and the laptop automatically would use the charger as a main power supply if the battery doesn't work
and oh by the way
If the battery isn't in it, your laptop will act as a pc whereas if you
plug the charger in it will work, but if you take it out while the
laptop is on then it will go off instantly without a successful shutdown
which could mean a loss of work
Regards,
Rahul
i forgot to mention it doesnt charge too...:( my battery doesnt have any power..now...:("
