SOURCE: Kenmore range model 790.90152300 the
The electronic oven controller has failed. The cost is around $160.00.
SOURCE: range works, ovens do not
CALL DACOR DIRECT AND ASK FOR MICHAEL, HE IS THE SON OF THE OWNER.
Dacor
1440 Bridge Gate Drive
Diamond Bar, CA 91765
Toll free: 800-793-0093
Main: 626-799-1000
Fax: 626-403-3130
SOURCE: Crosley oven worked yesterday but today I have no
check the receptacle for 220 volts. also check the connections where the cord goes into the back of the range - make sure you have 220 volts there also.. it sounds like you have only 110volts going to the range. there are no fuses that I am aware of.
you could also have a burned wire somewhere.
SOURCE: i have acquired a leisure rangemaster 110 dual
I know the answer. You ,must set the clock else the oven(s) wont work.
