Hold the power button down for about 20 seconds to hard reset the device. If it still only comes back to the logo you will probably need to factory reset the tablet. Consult your device documentation for instructions on a factory reset or google Factory Reset <Device Name>
if you have a google account, you can do this option
When you try different patterns and unable to unlock your phone in five attempts. Then a message pop-up and shows two buttons "next" and "try again".
Now click on "next" button and you see two options for unlocking phone. One is answer the security question and the second option is to provide Google account details.
Mostly people don't set a security question. But if you set it then simply answer the question and unlock your device quickly. Otherwise check the Google account option and click "next".
Now provide your Google account username and password attached with your device and click on "sign in".
After that you are directed to choose new pattern and now you can unlock with this pattern.
if you don't have your google account, you can do the recovery option, but you will lose all your data in there
Power off your phone.
Now press Volume up, power and home button at the same time and wait until your device starts.
When you see logo screen release the power button and keep pressed the other two buttons.
Now your screen shows android system recovery and there is a list. Use Volume up or down keys to select option from the list. And select factory reset option and then press power button to let the action begin.
Now it asks you for confirmation, select "yes".
After factory reset completes, it again shows you android system recovery screen. Now select reboot option and after restart it will not ask you for pattern.
you can try here and no that I don't know this site owner and cannot vouch for any software there. Suggest you download to desktop and scan with you AV before you install. Solvusoft Microsoft Gold Certified Company
In order to factory reset your device you will simply need to perform the following steps directly in order to reset your device.
1. Turn your device off
2. Press and hold the volume up button
3. Press and hold the power button
4. Release these buttons
5. Use the volume up and down keys to highlight the factory reset option
6. Press the power button in order to select the option to factory reset your device
Steps on how to do the restart. -You have to turn off the system. -Then press and hold the power button until you will see a message that will popup in a window that saying "Device Options"Appears on the screen. -Then select the power off again then you can see it again.You can be able to check that it first. -Then just select okay And while holding down the -Back -Button -Then Press and hold the power button. -Until you see the Coby`s Logo -Then wait until it change to Android Logo. - Then press the Back button.And Then the system menu will appear in the screen. -And then choose the wipe data/factory reset. >Home >Menu Buttons >Press the back,the button once you select the wipe data/factory reset then just click option. Then the confirmation that you will see in the screen Is a "yes" "Option". Then Choose "yes"-delete all user data,option by using the "Home"and "Menu"buttons. Then it will perform the factory data reset. -wait until it done. -Then once your done the main system menu has to appear in the screen. -And then reboot the system. -Then you have to press the back button to reboot the system. -The system will reboot the initial factory data setting. -All the user data will be lost. -Then Give the reboot,at least for 5 minutes. -Then Do not assume the unit has frozen.
It's simple. You can complete this task with several steps. Just follow below steps.
You are able to reset iPhone to factory settings within your iPhone. You just need to go to "Settings > General > Reset" and then choose the categories you want to reset and then apply it. If you choose "Reset All Contents and Settings", then you will get all the files in your iPhone erased.
Once you tap on "Erase All Content and Settings", you will be asked to enter your Apple ID password. Next, you will see a Popup Message informing you that All media, data and settings will be erased from your iPhone. Click on Erase iPhone to factory reset iPhone 6 Plus.
I am having the same problem with the mid7120. I bought two for my boys for Xmas. The appslib worked the day before Christmas. On Christmas day, I noticed their site was under maintenance. Now it says my device is not compatible on one and says to reset the date to June 20,2010 on the other.
