It does not have one.
See specs here http://www.fic.com.tw/everex//us/products/rs2800/rs2800.php
SOURCE: no pc card sockets installed on everex explora
You still have options
Either a USB wireless adaptor
Or
A USB to RJ45 adaptor
SOURCE: my Everex eXplora GS28 has
In your case, you may need to take step by step in order to find a culprit in what is causing the error. In a situation where you have no display on your monitor, there are many possiblity to the issue, and the best case scenerio to solving this promblem is having extra testing parts in order to actually know what is wrong. However 1) Check your monitor, if it's on, cable if they are secure and proper (power hdd lights) and if there are, take note of it and come back to tell us and we might be able to tell you what is wrong. 3) You will have to take this to a computer technician, as video card, bios, chipset, memory, cpu, or simply the motherboard is bad.... and the only way to make sure what is wrong is to have extra part to test this with. if it is giving you beeps, lights flashing, shutting down, and restarting automatic can better tell them/or us what is excatly causing the error. Sorry that this is no solution.... but before you do that, take your computer side panel off. when you see the motherboard ( the board with a fan and cable wiring going into) there is a battery about the size of a nickel and silver like a nickel, try to take that battery out, leave it out for a few second like 15sec, and then reinsert it back in, and then out everything back togheter and turn on your computer to see if anything work, if not, you have to take this to a tech to see what is actually wrong.
SOURCE: what key to enter bios
Turn the computer off.
Hold down any key on the keyboard.
Keep holding it down, and turn the computer on.
When you see the message "keyboard error, press <blah> to continue, or press <blah> to enter BIOS SETUP", then release that key, and follow the on-screen instructions.
