Depends which wireless headphones you have. Most headphones do not use WiFi, they use Bluetooth or 2.4 MHz RF. Usually a wireless headphone set will have a transmitter plus the headphones. The transmitter usually connects to the TV either with the analog L+R ouputs or the stereo headphone jack.
.you need a headphone preamp. Unless you have one lying around use any sort of tuner to go through. Xbox DVD player Vcr Cable box Ect Anything that has a headphone jack
It sounds like you have wireless headphones so maybe its not tv maybe more like transmitter signal between headphones and reciever so hopefully you have a way to test siganal. However the default headphone jack on TV should work fine unless turned off in audio settings in TV. Hope some of this helps you.
I'm pretty sure your soundbar has more than 1 input. Check your manual. There probably is AUX input on soundbar and that will allow you to connect to TV, assuming that your TV has any audio out. It could be either white and red RCA connectors or headphone jack.
You need to connect an audio patch cord between the laptop and the TV. Use the headphone jack on the laptop (3.5 mm M). Check your LG TV manual for the correct audio in on the TV. (Usually it is next to the VGA port if the TV has that PC input.) Computers do not send sound on the HDMI video output.
You can purchase a cable to connect to the Audio Out ports on the back of the TV. It will have 2 RCA connectors on one side that plugs into the TV and a 1/4" stereo jack on the other end that you will connect your headphones to. You could even pickup a pair of wireless headphones... they will have a volume control on them! I hope this helps.
Hi, If I remember from my LG Plasma, I had to go into the settings and
enable the headphone, but make sure you are not wearing them first,
just incase the sound is very loud.
Hi - the tv sound will be picked up like an fm radio signal at 83 mhz. To get there, press the reset button the side of the headphones, then press scan. the first signal to be picked up will be the tv signal. This assumes, of course that you have fresh batteries in the transmitter and headphones, and that the volume is turned up on the headphones and the TV. Worked for me. The signal is not stereo, though.
ya..you can connect your headphone to the
LCD tv.It will be available on the back of the
tv.The port will be available.
check this out..
thank u..
rate me..
