Jacuzzi toilet 1.28 Gpf/4.8 Lpf eco flush -flapper 3
SOURCE: toilet not flushing properly
there are allot holes around rime inside they get clogged over time because water quality very hard to get there to clean best bet replace toilet
SOURCE: cant find the right flapper for jacuzzi brand
Lowes used to carry some of the oversized flappers. If they dont anymore start calling the plumbing supply houses in your area. Hope this helps.
SOURCE: please tell me how to get more water in my toilet
The water level in the bowl is determined by the built in trap in the back of the bowl. Water is allowed to enter the toilet and it then "over flows" the p trap in the back when flushed. Once it's flowing, it syphons the water out of the bowl. While the tank is re-filling, a small portion of water should be running down the overflow from the small hose clamped onto the overflow This rinses the inside of the bowl, as well as helps-refill the bowl. Be sure that hose is directed inside the overflow tube. To see what the max water level in the bowl can be, add some water from a cup or glass. Once it's full you can keep adding and it won't get any higher. This will be the max level you can expect.
SOURCE: replacing flush valve jacuzzi toilet
I am having the same problem. Looks like we'll need to order directly from the manufacturer.
SOURCE: Porcher 6.0 Lpf / 1.6 toilet. Plumber said he
Try replacing the flapper, they are cheap and so long as the tank and or bowl are not cracked you can replace all of the internal parts and basically have a brand new toilet much cheaper then replacing the entire unit. Go down to your local hardware store and everything you need is in one simple kit with very simple instructions. Good Luck.
