This notebook is 1 year old and my wife uses it on an irregular basis. When she wanted to power it up it just turned itself off. I re-seated the ac adapter and after a few attempts, got it past the logon and then the massage appeared.cannot detect battery.
Check the end of the battery and make sure the pins are nice and clean also check inside were the battery goes and make sure its all clean in there,
if after all that it might be worth changing the battery if it still does not work.
or battery could not be charging anymore and its dead.
if not any of the above please get back to me.good luck.
SOURCE: No power/charge
Check that the battery is properly installed. Check the AC Adapter for power. Otherwise take the machine back to the seller. It is still under warranty.
SOURCE: asus eee pc sends terrible buzz from mixer to speakers when charging
Wrap some aluminum foil around your charging cord (right up to the point where it plugs into the computer)
This happens when elecromagnetic interference happens from the electricity from your cord and your A/V cords come too close together without protection.
Tin foil, any can's if you cut them properly, essentially just something to keep the interference away from the cord. You mostly notice this at concerts or if playing an electric guitar and it gets too close to the amp it creates a humming/buzzing noise that can get pretty annoying. Try the tin foil though that should work fine, don't be afraid to use a lot of it either, it won't hurt anything, the better wrapped it is the more likely you will get rid of the buzz
