1993 Yamaha 4 stroke - 50 HP It runs very rough at all throttle speeds. It acts like it is missing spark on one cylinder but there seems to be spark at all of the cylinders. Is this a gas flow problem then? What is the process of elimination for the cause of the problem.
Thanks
If it has the old points system you will need to set the points also adjust the carburatior screw the screws all the way in and back out 2 1/2 turns then get it to run turn the air mixture screws till it runs smooth. you want it slightly lean then enrichen it slightly, afterword shut the engine down and look at the plugs if they are gray black they are ok. good luck.
50hp yamaha 4 stroke dies when put into forward gear
The plugs were all sparking but I will be buying new ones tomarrow and giving them a try. Your right about it often being the problem and it is the easiest fix to try.
