SOURCE: LG Tromm Electric Dryer
NO it is not normal if it is only that old ....I would Call LG service it will still be under Warrty..(unless you are drying ball bearings)
Good Luck
SOURCE: lg tromm dryer electric cooling light staying on
I called LG after seeing this light as well and they say it's supposed to stay on and should "blink" at the end of the cycle. I've never remembered this light staying on in all the years of owning this machine but she (LG rep) said it was normal. Otherwise, if you've checked everything and it's not drying clothes, you may need to have your dryer serviced. :(
SOURCE: check filter light wont shut off and setting.lg tromm dryer
You might need to check the exhaust on the rear of the Dryer, or the blower motor iether one has lint inside, restricting the air flow
SOURCE: LG Tromm dryer now takes two cycles to dry a load
The problem with the LG tromm dryers are seemingly two fold.
1. The dryer stops heating and drying the cloths. I found out AFTER HAVING IT SERVICED TWICE AND WAITING A MONTH FOR A NON ESSENTIAL PART. The problem turned out to be the dryer vent going from the wall to the outside was severly clogged. Once this was corrected the dryer worked great.
2. The second issue probably is a design issue in that a large amount of lint seems to get by the lint filter and ends up in the vent that the dryer is connected to and goes out side the house. In my case I have a long dryer vent imbeded into the wall to the exterior, in a shorter vent this probably wouldn't be an issue.
SOURCE: my lg tromm DLG69885 gas dryer is not heating; oth...
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
you dryer is gas check out this gas
no heat
tip....
If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
