Teri,
I can't explain why this might work
but try this.
Disconnect the speaker from the phone's blue tooth by unpairing it
then reconnect the speaker by pairing it to the phone again for a fresh reconnection via blue tooth..
Had this issue with a Jabra blue tooth speaker on my wife's mobile phone was doing the exact same symptoms !
It was very very annoying but doing the pairing again fixed it .
No where from the specs of this model it does not have Blue Tooth capabilities. From the user manual there is no Blue Tooth capabilities. Pairing code would be for Blue Tooth.
You could use a 802.11N WI FI ethernet device and connect the TV to it but no blue tooth .
first you have to turn the power to blue tooth on ,then you will have to put ur speaker into discovery mode,most blue tooth manufactures use the power button for this feature by holding it down for 6 to 10 seconds when turning on the device it will put it into discovery mode,your phone or computer or game system should be able to recognize the blue tooth device then.It will ask you for a pin pairing code,now most manufactures use a factory 4 digit pin pairing code they are as follows 0000,1234,1111,or 9999 hope this helps
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device. Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hi, you will need pair both phones together before you can be able to send .
Hi, first reset the phone and try to connect again.
If it connects,you can use this step to,But if it doesn't connect that means the blue tooth is corrupted and will need to be flash to restore back blue tooth.
(You will have to flash the phone to restore the memory of the phone. You can use this link to see how to flash your phone. (hubpages.com/hub/How-to-Flash-your-cell-phone) and (unlocktotalk.com/UnlockCodeInstructions.htm.)
HOW TO CONNECT BLUE TOOTH,
