I have an Electrolux EW Aqualux 1200. Two weeks ago a sock was stuck into filter. I removed it, switch off/on machine a few times, ran machine empty. However since then machine is spinning only if it is half full. Machine is 9 years old but I will be happy to repair it if it can be?
SOURCE: electrolux aqualux 1200 ew
I had a similar problem with a different make recently. After cleaning the filter which didn't seem to have anything in it and rinsing the filters on the in and out pipes I took all the clothes out and ran it empty on two different full programmes and somehow the gremlins disappeared and it works fine now.
SOURCE: washer/dryernot drying-Electrolux - Aqualux 1200 EW
check the drain filter is clear / pumping efficiency good. possible blockage in side chamber on righthand side. fan motor assy on top of chamber may be faulty. a condensing water valve could be faulty its the dual cold valve that the cold hose connects to without it you just get a steam and hot clothes.
