Ricoh Aficio MPC3500 Logo
s
shakeel Posted on Mar 14, 2015
Plz help sc 681 in ricoh mpc 4500
Sc 681 in ricoh mpc 3500
renja rollex
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 14, 2016
renja rollex
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
961
Points
• NoiseRFID: Communication error • Communication error occurs when the RFID starts to communicate with the RFID receptor. • Retry of RFID communication fails three times after the machine has detected the RFID communication error.
The problem is Defective RFID reader and writer • Disconnected ASAP I/F • No memory chip on the toner cartridge • Noise
ERROR SC 672 IN RICOH MPC 6000
SC 672 is a controller error. So possible is tat the controller board is defective, in best case can be only the ram memory dimm's or the HDD but in most cases the controller board is dead.
Ricoh mpc 350 error school 972 what is the resion Ricoh mpc 3001 error code sc 972 how I can fixed it
If you wish to get some details about printer repair and service; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Ricoh mpc 6000 sc 670
Engine startup error - sudden communication reset between controller and VBCU 7/29/2008 Helpful SC 670 Engine startup error - VBCU defective 7/29/2008 Helpful SC 670 Engine startup error - VBCU installation incorrect 7/29/2008 Helpful SC 670 Engine startup error - LCT lift tray sensor was shorted 9/2/2008 Helpful SC 670 Engine start up error. Check main power supply, cn 409 for 5volts 7/20/2009 Helpful SC 670 Engine startup error - Replace laser unit and follow SP adjustments after laser unit replacement 4/5/2010 Helpful SC 670 Engine startup error - IOB board defective 6/8/2010 Helpful SC 670 Blown fuse 2 on VBCU due to shorted harness in registration motor harness 6/8/2010 Helpful SC 670 Engine start up error - Check wiring for df feed in cover.. 8/6/2010 Helpful SC 670 Engine startup error - Replace finisher main board 10/26/2010 Helpful SC 671 Controller mis-match error - Install correct controller b
THIS UNIT IS VERY HARD TO WORK ON YOU NEED A SERVICE CALL, GOOD LUCK! -Carl
Jai un C3500 mp Aficio de Ricoh qui a sc erreur 792
finisher cable not plug into copier. I f you don't have a finisher don't worry about it or you need to remove bridge unit to get rid of code.
3helpful
2answers
Problem with the Ricoh mp c2800 Ricoh error code sc 672,
If the model ia a MPC 2800 it a controller board issue maybe the operation panel. -carl
Ricoh rex rotary sc 548
Hello wajidsn
SC548 : "Fusing Installation Error.Fusing Unit Set Error"
Top Ricoh Computers & Internet Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Ricoh Computer and Internet Expert? Answer questions, earn points and help others
