Date & time set per instructions. Does not show the icon nor does it print the date & time on camera.
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
SOURCE: kodak easyshare Z812 IS date on pictures
you should be able to find the menu amd scroll down to date time set
otherwise go to kodak.com
SOURCE: how do i change the language and set the correct time and date
Way to misrepresent yourselves
What a bunch of ****.
SOURCE: Can't reset Date & Time
What you have to do is go to the icon with the spanner (as shown above) and keep tabbing down. There are more options than just the ones you see in the screen (not just High Power , Auto, Set Tag, On), keep going down and it will show you the other options. You will see the date change icon about 7 or 8 down.
SOURCE: reset date/time stamp
Here is the only information I could find for you. This is a link to the extended user manual. You want to look in two different places. The 1st place to look is "setting up your camera". From there there is a heading for setting up the date and time and language. The 2nd place would be "Doing more with your camera"
http://www.kodak.com/global/en/service/publications/urg00846toc.jhtml?pq-path=12649/12701
Hope this helps.
SOURCE: My M863 changes the date intermittently to a
hello,
Everytime you removed the battery of your camera, date and time will be reset. You have to set the date and time correctly.
Follow the steps below.
1.Press the Menu button.
2.select the Setup Tab, it has camera w/ tool icon
3.Scroll down until you select Date and Time
4.Press Ok then set the date and time.
Thanks.
Neerak21
