Have you replaced your exhurst system if you have did you put the O2 sensor back in as f1 error code is for this sensor and your CPU can not tell if the engine is running correctly and will shut the engine down when a gear is selected
I HAVE A 2005 GSXR 750 AND WHEN IM AT HIGH RPM THE BIKE SHUTS OFF. DOES THIS HAVE ANYTHING TO DO WITH THE FI CODE BLINKING? BUT THERE ARE DAYS WHEN IT RIDES FINE....WIERD
normally the f1 code stands for failed matrix in the control brd behind the panel. by removing the panel, after disconnecting power you should find a tech manual which should show the code and solution
for the F10 code ? Unplug the washer open chech the funny noise / belt are worn out / slap to the brackets and other near obstacles . Replace belt broken.
Detergent leaking /ovewr flow clean w/ fish nylon # 150 just 40 cm /insert in the hole put water to soften the hard detergent forward and backward to clean detergent hose.
