Polaroid Tablet Computer PMID701 Logo
A
Anonymous Posted on Mar 12, 2015
My tablet wont it wont turn on even after we wiped it and reset
Wont unfreeze or reboot at all ...polaroid tablet # ptab735
William Alequin
Level 3:
  • Polaroid Master 932 Answers
  • Posted on Mar 12, 2015
William Alequin
Polaroid Master
Level 3:
Answers
932
Questions
0
Helped
201532
Points
2855
We need to know what is doing exactly in order to get the proper help. But if it get stuck in the boot, or it's in a bootloop after a hard reset, then you should flash a new firmware. That should fix it without a doubt. If, and only if, it still have problems booting up, then you have what its call a hard brick, meaning that there is a problem with a hardware, probably the processor or any of the motherboard component.
How do I unlock my Polaroid internet tablet this to KGB cuz I can't remember my passcode
you will after hard reset the tablet you will loose everything on the tablet
hold down the power button and the volume down button at the same time till some writing comes up
then go down with the volume down button and highlight wipe data
press power button to ok it
then go down to yes highlight yes press power button to ok it
then it will reset then go back to the writing go to reboot press power button to restart the tablet
My polaroid tablet will not boot
polaroid pmid701c tablet stuck at polaroid screen when rebooting ...
freaktab.com/.../tablet.../polaroid-tablets/835-polaroid-pmid701c-tablet-s...
Apr 14, 2012 - It just won't go past the Polaroid screen when booting. ... At this pointPolaroid has not released the factory ROM to be reflashed, supposedly sometime within the ... There are ROM's from Onda that does seem to work well. ROM ** Polaroid AS8 ** ROOTED + TWRP
Dec 24, 2013
Polaroid ptab7200 does not turn on
May 8, 2012
More results from freaktab.com
my polaroid tablet won't turn on - Tablets - Android Tablets - Tom ...
www.tomsguide.com/forum/id-2079971/polaroid-tablet-turn.html
Jun 20, 2015 - 6 posts - ‎5 authors
I have a Polaroid Tablet, Model PMID702C. ... Now, it will not power b. ... my tablet wont turn on , and when i charge it its not working how can i ... My Samsung tablet will not turn on. - Samsung
Dec 30, 2015
My tablet won't turn on! - Battery
Jun 19, 2015
my tablet pc got boot loop - Tablets
Jul 28, 2014
Help! My tablet won't turn on! what do I do?! - Asus
Nov 5, 2013
More results from www.tomsguide.com
Need to reset. grandson loged
Hard reset, Press the volume up and power button for about 10-15 seconds to reboot. Wipe data/Factory reset.
Why is my polaroid MID0748PMP01.133 it wont get past.always return in to the android system reboot menu
Be sure nothing is pressing against the volume button when you turn it on, and that the volume button isn't being jammed down by anything.
How do i fix my tmax tablet that wont reboot
if you can shutdown it.
boot in recovery mode and use this command ( wipe data / factory reset ) and ( wipe cache partition )
Tablet wont boot
turn it off then hold volume up and power until get recovery mode then using volume key to select wipe factory then click power then after finish select wipe cache then reboot 12_7_2013_12_41_10_am.jpg
4helpful
2answers
My tablet wont turn on it continues to blink but wont turn on
Try using a paperclip to reset it on the back, hold it in for 5 seconds, if that doesnt work:
Turn the tablet all the way off, press and hold the VOL - and power at the same time for 8 to 9 seconds, it will show a green android guy with a system recovery menu. Use vol - to go down to Wipe Data/Factory Reset, press the power button to select it, go down to 'yes' to confirm, press the power button to select it, it will wipe the tablet, you then press the power button on 'reboot system'.
5helpful
D2 pad wont go past the android sign,frozen
I had the same problem even tried the eset button on the side but nothing worked. Opened ticket with customer support and they advised to do system wipe and factory reset....to do this press teh vol + and vol - and power button all at the same time for 8-10 secornd, until blue screen appears, select "wipe data/factory reset" by using the vol buttons and select using the poser THEN select "YES - Delete all user data"
Obviously you will lose any data but when you can't use the tablet you don't really have an option.
After the system tells you the process is complete you can select the reboot option.
At this point my tablet appeared as is from store.
Top Polaroid Tablets & eReaders Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
nexrad_chris
Are you a Polaroid Tablet and eReader Expert? Answer questions, earn points and help others
