Troy-bilt 2200 psi pressure washer has no pressure and water is shooting out the chemical mixing tube
I have a Troybilt Model 2200 PSI Pressure Washer in which I have used only 2 times in the past 2 1/2 years. Went to use it this past weekend and the pump in not working. Water shoots out of the side. I bought this brand and model as I thought Troybilt was suppose to be so good. Went back to where it was purchased and had no success but to say I could buy another pump or take it in to be repaired. I believe that this power washer should be replaced at no charge. 2 uses does not constitute a few hundreds of dollars.
Have you to heard anything concerning pump problems on this particular model? Thanks for any advice. .
Be sure to check for a small spring and ball bearing in the fitting where the detergent hose connects on the Troybilt 2200. If these are missing the pressure washer will not build up pressure and water will squirt out the detergent hose. The spring and ball bearing act as a check valve to allow the detergent in but if they are missing then water will squirt out.
