Watches Logo
Paul Brinkley Posted on Mar 12, 2015
I have a Henry's citation 14k pocket watch serial number 450815 how old is this watch
5 Related Answers
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Jan 05, 2009
SOURCE: opening an elgin pocket watch
The best tool to do it is watchmakers knife, but any proper knife with hardened steel blade can do the job. Make sure the blade is NOT flexible.
Check carefully the sides of your watch and you will notice the groove. Place knife blade into that groove and press it in. At the same time try to make a scooping turn to lift the caseback. Usually there must be underlayed caseback as well and it opens exactly in the same manner.
Make sure you do all this carefully and do not let the blade to slip or your watch will end up with nasty scratches or even damaged movement.
That job isn't a big deal, but requires some skill, so, BE CAREFULL.
Don't forget to rate, please.
Anonymous
  • Posted on May 28, 2009
SOURCE: Trying to identify an English watchmaker
No solution, but can give you information on Henry Stuart, as he is part of my family history. 1803 Liverpool - 1882 Oxton Cheshire when still described as a watchmaker. Making watches from at least 1825, in Park Lane Liverpool & later in Coventry too, but business suffered from the advent of cheap Swiss watches. Specialised in very beautiful cases, we are led to believe.
Fiona Hedges,
Oxford
Testimonial: "Very helpful! Still doing research."
Anonymous
  • 2501 Answers
  • Posted on Jan 05, 2010
SOURCE: I have a silver case Jos. Johnson key wind pocket
If you go to Wikipedia and type in "
Joseph Johnson (watch maker)"
you will see there are a number of reference documents listed. The information you look for may be in one of these.
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Jan 28, 2010
SOURCE: hello, my longines 14k 17J, case number 975099 Can
Contact Longines yourself by following this link: http://www.longines.com/contact/faq/products Find the best suitable way for you to get in touch and ask for the information you are after. Rate me, plz.
Anonymous
  • 2501 Answers
  • Posted on Jan 30, 2010
SOURCE: how find serial number on ~1910 hamilton pocket
The serial number is usually engraved on the movement. If you open the back of the watch, you should be able to see it.
I looked at the Hamilton pocket watch site (in might be helpful if you visit the site, simply type "hamiltonpocketwatches.com" into your search engine and your will be able to examine photos of a number of movements).
The position and size of the number varies but it shouldn't take to long to find. One of the pictures I found impossible to see the number but the rest I found, although sometimes you had to look quite carefully.
My 14K GOLD BENRUS has a Serial # 435626. How old is this watch?
Go to this site and post the question. It's probably not worth very much - maybe less than $200 unless there's something special about it...
1helpful
2answers
Find out if a watch i have is worth money
Check to see if your watch or one closely resembling it, is for sale on Ebay. This generally gives an idea of value, at least in terms of resale and value. Watches, other than Rolex and very high end types, don't have very good resale value. Of course, all of the value may be in the diamonds or 14K cases, no matter who is the maker.
2answers
Does the Movado ladies watch serial number 74259821 836092 have a solid 14K wrist band?
The 74259821 is definitely a 14k solid gold watch. I have one, too, and need an extra link for it if anyone out there has one. 267465b2-5058-4a86-99d3-8e2eb936415b.jpg 83ef6643-49bf-4f76-97f1-639d71b4c025.jpg
What do the number on the back of the Geneve Diamond ladies watch mean.
There may be three number on the back of a watch.
1) The case number.
2) the movement number.
3) the serial number for the case +watch assembly.
2helpful
Fiona Hedges,
Oxford
Top Pocket Watch Watches Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
ADMIN Eric
ADMIN Eric
Are you a Pocket Watch Watch Expert? Answer questions, earn points and help others
