This device comes with AMV Converter, which will convert your video files to the best format / size for this player. I am not seeing any information on native resolution / frame rate or anything like that for this device, but since it has that AMV Converter utility it will definitely convert your files to a format that works properly with the unit. If you still have questions or need further help please respond to my answer and I will get back to you right away.
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
You need a format converter to convert your music video to AMV.
You can download a free AMV format convert at the following website:
http://www.brothersoft.com/downloads/amv-convert-tool.html
Good Luck, I hope this has helped you.
Please rate me, Thanks
I have the player for my brother for christmas and had to pre-load it for him.
You have to download a program called AMV video converter.
This particular mp4 player only uses .amv movie files.
Some use .amv and .mtv but this one uses .amv and you can convert almost any movie file .mpg, .mpeg, .avi, ect... into .amv
Then just drag and drop it and play!.
Make sure you check all settings and make the video conversion big enough to see on the player.
Hi! Can you see an icon namely setup in amv transfer tool or AMV tool setup? If yes then double click it and it will install the software needed to run your player. And after the software and drivers get installed connect your player to your pc.
Try put in it in manually Go to the following folders Record > AMV > and put the video in there....remember the video must be converted into a AMV file
