SOURCE: zeroing problem
Make sure you rest the air rifle on something soft, like a folded jacket for a rolled up towel.The rifle will always shoot away from a hard surface.If you rest against the side of a tree, it will shoot away from the tree.If you leave your pellets in the sun, and they are warmer than the barrel, they will always shoot high.Good Luck
SOURCE: air rifle?
Most rifles will hit whithin at least one inch across a normal back yard. You're quality is going to come from the manufacturer. CO2 and Air Pump is a personal choice, I have noticed no difference in performance, though some say CO2 is more reliable. Daisy is a classic manufacturer and has some modern, good weighted rifles that will shoot dependably. Anything with a Walther barrel or the Walther name is a good investment when it comes to rifles (not so much for pistols). Break barrel actions are prone to jam, be difficult to open once lead shavings build up, and pinch nastilly, and if you have a child or are a novice shooter yourself, a traditional action will help you learn proper habits early on. You really shouldnt spend 300$ for an Air Rifle, or even 200...Maybe even 100.
SOURCE: how do you load crosman quest 1000. never owned a
You load one pellet at a time when the barrel is broken open, the chamber is in the break of the barrel. One stroke, load, close, shoot, keeps you in shape. the old Sheridans, 10 pumps, really kept you in shape.
SOURCE: Barrel will not stay open when broken for loading.
bad triger,,,getb it fixed,,,as for the bent barrel they bend if you let them spring back a lot!
SOURCE: when I **** the barrel to compress air it won't
If it new, it must have a warranty of some kind. Use the link below to contact customer service for help.
Crosman recommends that you take to a service center, and adds the following. >DO NOT ATTEMPT TO DISASSEMBLE IT< Your Phantom requires special tools and fixtures to repair it. Any disassembly or modification not performed by an authorized service center will void the warranty.
Crosman customer service
http://www.crosman.com/airguns/service
