Unit is obviously in defrost too long. Verify defrost clock operation and time setting.You may reduce the amount of minutes per cycle that defrost is actually called on for . 20 minutes should be adequate if you are defrosting more than once per 24 hrs. Defrost clock should have "X" terminal which will terminate defrost once evaporator coils reach a certain temp. It is controlled by a three wire defrost thermostat relay(clixon) attatched to the actual coil in the event this coil reaches 50 degree,the clixon triggers the "X" wire in the timer and terminates defrosting.It figures if it reaches 50 degrees,it must then be free of ice on the coils
