Question about Onkyo Ht-r510 5.1 Channel 100 Watt Av Receiver
After turned on the power, the unit shuts down immidietly
    New Friend:
IA M ALSO HAVING PROBLEMS WITH MY RADIO IT SHUTS OFF AFTER 2 MIN WHAT SHOULD I DO JUST DONT UNDERSTAND AND WHAT IS THE COMPANY ADDRESS PHONE NUMBER
Posted on Mar 12, 2015
    Top Expert:
  • Onkyo Master
  • 12,962 Answers
There is a problem in either the power supply or amplifier output stages. The unit is programmed to shut down in such an event to protect other circuitry.
Using a schematic see if you can isolate the power going to the output stages. If unit stays on then the anomaly is in power amp stages. If it still shuts off problemo is in power supply - check diodes and capacitors.
SOURCE:
The receiver after turning off will turn it self back on, repeatedly.
The unit is drawing too much power and is being protected by a current/temp sensitive device that shuts down to protect unit. When it cools, the power is restored until it heats up again, and the cycle continues.
Sounds like something in the power supply area is the cause of the anomaly.
Mar 21, 2015 | Audio Players & Recorders
Onyko tx nr616 receiver keeps shutting off. Only stays on for approximately 3 seconds. Can you help?
The amp protection circuit has been activated. Remove the power cord from the wall outlet immediately. Disconnect all speaker cables and input sources, and leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect the power cord and reconnect an input and a pair of speaker wires onto the unit. If the receiver still does not turn on than you will have to bring it in for service. Turn up the volume and if the receiver doesn't shut down, power off the receiver and add another pair of speakers. Power up the unit again and turn up the volume. If it doesn't shut down, power off the unit again. Now connect all your input sources and turn on your receiver. If the unit shuts down again, your unit will need to be further serviced at an authorized Onkyo service center.
Sep 30, 2014 | Onkyo Tx-nr616 7.2 Thx Certified Network...
How do i check to see what is causing my receiver to shut off
Sep 25, 2014 | Onkyo Audio Players & Recorders
Onkyo ht-rc180 standby light blinks will not start.i tryed factory reset, still blinks
Sep 24, 2014 | Onkyo Ht-Rc180 7.2-Channel A/V Surround...
Hi this is what i get when you turn on the PC takes a few seconds and shuts down the PC. "SMART Faulure Predikted on Hard Disk 4 : WDC WD3200BEVT-222CTO-(S1) WARNING. IMMidietly back-up your data...
SMART is to measure your Hard Disk Drive health. This warning tells you to backup important stuff and prepare to replace the HDD. If the computer can no longer boot into Windows, connect the HDD to another PC or you can also get one of those HDD enclosures which will let you connect the HDD to other PC's through USB connection so you can backup your files.
Hope this help, goodluck!
Mar 29, 2011 | Fujitsu AMILO PC Laptops
Delfield mini freezer for restaurant is not freezing. Unit has power and cabinet fan runs but comp tries to kick on then you here a click and it immidietly shuts off before it can really ever start. Hi...
Compressor is locked up. You have an outside chance of getting it to come back if you install a hard start capacitor. When a locked compressor tries to start it gets hot really fast and kicks the power off to prevent wires from overheating. You can get a hard start kit from wwgrainger or refrigeration supply company. Many times they won't sell direct to the end user. The hard start kit gives it an extra boost when it tries to start. Most times this won't work. Usually the compressor has to be replaced because it is burned out internally. The hard start kit is less than $20.00, so its worth a shot.
Sep 21, 2010 | Delfield Freezers
Unit re-powers after being turned off. Only removing the battery gets it to shut down without re-powering.
When it repowers,is it because when you hold the unit,it repowers? Then once it shuts down put the unit down.
Feb 15, 2010 | Focus Enhancement FireStore FS-4Pro HD...
C80 display is locked up
When turn on the power on the switchpanel immidietly
press the first grey bottem near the powerbottom so long till it shows you factoryreset after this look wich software you have it shoud be 4.29.
if not use a CF card to install .
Apr 26, 2009 | Raymarine C80 GPS Receiver
Unit is always shutting down / turning off
Try first unplugging power cable for five minutes and using a different power outlet, if you still get the problem, the unit has a faulty power supply on the board inside.
Nov 12, 2008 | Pioneer Televison & Video
Blinking green power light & shut down
There are (4) 1000uf @35V capacitors all together on the DM board that need to be replaced some models have 1000uf @ 16V but they are all right beside each other and all rated at 1000ufs the voltages will be stamped on the capacitor along with the uf ratings.
Apr 07, 2008 | Mitsubishi WS-55515 55" Rear Projection...
Onkyo Ht-r510 5.1 Channel 100 Watt Av Receiver Logo
459 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
