Most fuel filters are located between the fuel tank and the fuel injector. Your owners manual should have the location of the fuel filter listed. If the manual doesn't list it's location, you can ask at your local auto supply store or car dealership parts department. You can find more information here: http://www.xcardiag.com/
The Fuel Filter is located:
FUEL FILTER
1992 Mercury Topaz 3.0L FI 6cyl
FUEL FILTER
1992 Mercury Topaz 2.3L EFI 4cyl
Under hood, passenger side, upper engine area, mounted in fuel line
Before servicing the vehicle, refer to the Precautions Section.
NOTE
The fuel filter is located underneath the vehicle in the area of the rear suspension.
Relieve the fuel system pressure.
Raise the vehicle.
NOTE
To remove the lines, press the quick-release tabs on the connectors.
Fuel filterFuel filter and bracket assemblyFuel filter linesEVAP vapor line
Start the engine and check for leaks.
NOTE
Raise the vehicle.
NOTE
Remove the fuel filter bolt and remove it from the bracket.
Fig. Location of fuel filter and lines.
To install:
Position the fuel filter into the bracket. Ensure the fuel flow direction is properly aligned.
Install and tighten the fuel pump bracket bolt.
Lubricate the fuel tube fittings with clean engine oil. Align the fuel tube fittings and press together until a click is heard and then pull on the fittings to make sure they are fully engaged.
NOTE: The fuel filter is located underneath the vehicle in the area of the rear suspension.
Relieve the fuel system pressure by removing the fuel pump fuse from the battery junction box, starting the engine, and allowing the engine to idle until it stalls.
Raise the vehicle.
NOTE
The fuel filter for your vehicle is located on the Fuel Pump Unit, which is located in the vehicle fuel tank. The Fuel Pump Unit must be removed from the top of the fuel tank in order to replace the Fuel Filter.
The fuel filter (2) is located under the rear of the car, behind the fuel tank. There is no service interval for fuel filter replacement. Replacement is required only if the fuel filter becomes restricted.
All of the fuel filters with exception of the V6 Odyssey models are located on the vehicle's firewall, in line with the fuel line feeding the engine's fuel rail. The fuel filter on the 3.5L V6 Odyssey is located in the fuel tank and requires fuel pump removal to access. Fuel filters located on the firewall should be replaced if the fuel filter exhibits signs of seepage or corrosion. Always replace a fuel filter and its sealing washers if the fuel system has become contaminated, if the fuel system fuel pressure drops below specification prior to replacing the fuel pump, or whenever the fuel pump is replaced.
