Do you know how to do automotive electrical testing ?????? How to read a wiring diagrams ????
http://www.bbbind.com/free_tsb.html .Videos on youtube
Ohms Law Tech Tip from L1 with Dave Hobbs Copy of Voltage Drop Essentials TST Motor Age The only way to find the problem , testing !
Sunroof Description and Operation (One Connector System)
Sunroof
This diagnostic procedure is to be used for the 1 connector Sunroof System that combines the sunroof control module with the sunroof motor/actuator.
The Sunroof System consists of the following components:
• BATT MAIN 2 Fuse 50 A
• Body control module (BCM)
• RAP relay
• S/Roof Fuse 20 A
• Sunroof module (includes sunroof motor/actuator)
• Sunroof switch
The Sunroof System is controlled by the sunroof switch and the sunroof motor/actuator assembly.
When the ignition is turned to RUN or ACCESSORY, or when the retained accessory power (RAP) system is active, the body control module (BCM) applies a ground to the RAP relay in the instrument panel (I/P) fuse block. This activates the RAP relay and allows battery positive voltage to be applied through the SUNROOF Fuse to the sunroof module. Ground for the sunroof module is supplied from G302.
The sunroof can be placed in 3 preset positions:
• Open
• Vent
• Closed
When the sunroof switch is placed in the OPEN position, a ground is applied from the sunroof switch low reference circuit , through the sunroof switch and to the sunroof switch open signal circuit. The sunroof motor/actuator then applies voltage to the sunroof motor open control circuit and applies a ground to the sunroof motor close circuit. The sunroof motor then opens the sunroof to the full open position.
When the sunroof switch is placed in the VENT position, a ground is applied from the sunroof switch low reference circuit , through the sunroof switch and to the sunroof switch open signal circuit. The sunroof module then applies voltage to the sunroof motor open control circuit and applies a ground to the sunroof motor close circuit. The sunroof motor then opens the sunroof to the VENT position.
When the sunroof switch is placed and held in the CLOSED position, a ground is applied from the sunroof switch low reference circuit , through the sunroof switch and to the sunroof switch close signal circuit. The sunroof module then applies voltage to the sunroof motor close control circuit and applies a ground to the sunroof motor open circuit. The sunroof motor then closes the sunroof.
The sunroof can be placed in any preferred open position when:
• The sunroof is in the fully opened position by pressing and holding the sunroof switch in the CLOSE position until the panel has reached the desired position then release the CLOSE switch in order to stop the sunroof
• The sunroof is opening, it can be stopped by momentarily pressing either side of the switch.
The sunroof control module, sun roof actuator, and the sunroof motor are integral parts of the sunroof module assembly and are not service separately.
Your best bet , take it to a qualified repair shop or buick dealer .
