Microtek ScanMaker 8700 Pro Design Flatbed Scanner Logo
Posted on Nov 13, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lamp failure Lamp is dead, and I would like to buy a replacement and fit it myself. Don't know the part number, and where to buy it. The solution i was given is to send the scanner to the official microtek repair centre. Quite expensive. Many thanks for any tips. Fran
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 06, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
300
Points
The E6 Scanner lamp can be substituted by a standard
F8T5CW lamp. It is 12 insches long, uses 8 watts, is in the
T5 tube size with two prongs at each end and cool white, not
warm white. The replacement lamp works fine.
Anonymous
Level 2:
Novelist:
  • Expert 85 Answers
  • Posted on Nov 16, 2007
Anonymous
Expert
Level 2:
Novelist:
Answers
85
Questions
0
Helped
59036
Points
126
Unless this scanner cost more than a hundred dollars, it is hard to imagine how to fix it in a cost effective way. Good scanners are pretty cheap now, too, around $30. You could also try to find a replacement scanner of the same type on eBay...
1helpful
Can I buy and replace lamp myself?
Yes, a replacement lamp can be purchased through EBay, you must have the number of the lamp. Then look it up, the company is Pure Glare I think. It can cost anywhere from 30-80 dollars.
I am looking to buy an exercise band for home use but I don't know which one to buy. I want to be able to use it for a variety of exercises. Can anyone recommend a good one?
I recently bought an exercise band myself and this one was recommended to me by a trainer at my gym. I would recommend looking at it. Here is a website:
http://www.simplefitnesssolutions.com/products/exercise_band_kits.htm#FIT-TUBE & CLIP-TUBE KIT
I know whats wrong with my tv mitsubishi will not let me order the part or give me the part # for the WD-57734 dlp tv I need to order the lamp ignition circut board because of a short in the board where...
Are you looking for the Ballast for that model? You should be able to google the model number with the word ballast after it and find it with ease.
It is a nasty game where they don't sell parts, just the entire board.
I am here to give you as much help as possible.
SD Tech
1helpful
Lamp expired can I find a new lamp & can I replace it myself
Hello Ann Welford,
Welcome, and thank you for using FixYa!
To answer your question: I don't recommend replacing the bulb on this unit.
Not only did HP design these scanners in such a way as to elimnate "User changable parts" but it would not be cost effective. You can buy a replacement scanner for this unit for close to $75.00 and it will have newer features and software controls.
Have a great day!
My jvc tv has a weird color to it and it says replace lamp lite blue is this something i can buy and put in myself?
Yes you can replace Lamp yourself! look on back of TV and write TV model number down. A lamp code can also be found on back of tv or located near Lamp DOOR.Easy replacement!
I have a toshiba and i need a lamp bulb but dont know what sides i have a number off the tv
Tries websites like Ebay.com,Partstore.com just follow ur tv brand and model #... than buy the projection lamp for the replacement.U have the tv brand and the model #...the projection lamp will fit ur tv,because they come in standard sizes for it.
1helpful
2answers
Just replaced a new lamp. TV tried to turn on/off
Ur tv have a Ballast board that help to ignite the lamp.U hear alot of clickings,that mean the ballast board is dead,not doing it job.Tries websites like Partstore.com,Ebay.com to buy a new Ballast board for the replacement.
Where can I buy a Lamp FH&-3282
You could probably buy one directly from a third party part supply store over the internet like Ames Supply Company, Katun, or Precision Roller. I only use Canon parts myself but these parts may be a substitute for Canon. But I believe the Part Number is FH7-6080-000 for the scan lamp. Be sure to uplug the copier before replacing the scan lamp because the connector has AC voltage at the contacts. Good Luck.
Top Microtek Office Equipment & Supplies Experts
Alexander
Grand Canyon Tech
Grand Canyon Tech
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
