This TV is 1080p, 120Hz, it does have closed caption & timer.
see the following web site: http://reviews.lcdtvbuyingguide.com/samsung-lcd-tv/samsung-un46h6203.html
http://www.newegg.com/Product/Product.aspx?Item=N82E16889354743
SOURCE: closed caption and black square
your TV do not disable close caption in composite mode. It may in component mode. Please make sure that the close caption in your TV menu is not set to "text"
Please be advice that CC :Text is the ONLY one that can give you a black box.
Best regards
Circuitcity
SOURCE: avol ALT42FD120 - frame rate change 60-120hz?
Hi. It is entirely possible that the set is already running at 120Hz after all. The display 1080p 60Hz is merely the signal it is receiving and the earlier TV's that used to claim 100Hz/120Hz merely did so using line doubling only to give a clearer picture by filling in the blanks between scanlines. If your picture is already very clear, then I wouldn't worry about it
Testimonial: "indeed, thx 4 ur time"
