Please set up an appointment with a handyman with a site like Angi or Home Depot repair services to get an intial diagnostic. You might need to have the whole door replaced as the current oven door is safety hazard.
You need your burner replacing, order on line, just goole your oven model, you will need your serial number, half price of buying from your gas fitter, mine was, it's a five minute job to fit for a gas safe plumber
Their are 2 types of ranges. Ones with sealed burners and ones that do not have sealed burners. The sealed burner ranges must have a kit to replace the orifices. The none seal burner models are simply called crank down and flip models. That means you flip the screw on top of the regulator to where it reads LP. and then you tighten down the spuds on the top burners and the oven valve and then you adjust the air shutters.
Note: Some stoves with sealed burners cannot be converted to LP. The model number you posted is not a correct model number.
The oven gas valve coil has failed Need to replace. Go to repairclinic.com and put in the model and order the coil for the valve. It controls the gas valve.
