The Internet has a large number of web sites
where you can buy service manuals and schematics
from bookstores, publishers, and other collectors.
Factory Auto manuals
Factory Auto Manuals is specialist dealer in quality used factory car...
Repair Service auto Manuals
where to buy Factory Service Auto Repair manuals
Free Repair Service Manuals
Chilton Repair and Service Manuals
http://www.chilton.cengage.com/
Haynes Repair and Service Manuals
Haynes is the information resource for the DIY enthusiast
SOURCE: VW Passat transmission
I got same problem now. Did you find a Solution or figure out why transmission will not engage after being towed. Same engine works great just won't shift in to gear and go.
Thanks john
SOURCE: 3 LETTER TRANSMISSION CODE
the transmission and its control unit must be compatible. So, no, you should find the same code transmission.
SOURCE: 2000 VW passat maf
I would trust them but make sure it is just not in need of some kind of cleaning.
SOURCE: i need to know where is the dip stick to check the
There is no automatic transmission dip stick on your car. There is a long procedure to check and fill and you will need special fluid from VW. Better left to the dealer. If you want the procedure let me know.
Dave
SOURCE: Removing 2000 VW passat door panels
The door panel comes off With a T-10 torx or a Hex (Allen) wrench
that will fit and A large Philips Screw Driver..
Remove the Plastic cover on the inside Door handle.
And the Screw or Screw along the Bottom of the door panel.
Then remove the screws that hold the handle the the door.
They are located behind the Plastic plate you removed with a tiny screw driver earlier... Be careful not the mark up the cover whaytprying it up. It is best to pry from underneath. Where marks if made can not be seen
After the screws are out 4 I believe. The Use of a CLip tool ir best.
For getting behind the panel to pop it off. A screw driver will work.
After all the clips are released. Pull the light at the bottom of the panel down and out. Disconnect it ur push it back thought the hole it came from..
reverse to install
SKETCHLAB.com
