Canon PowerShot S2 IS Digital Camera Logo
A
Anonymous Posted on Mar 11, 2015
When i want to take a picture, There is an alarm, and I'm not able to take my picture.
Paul Green
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Canon Expert 527 Answers
  • Posted on Sep 02, 2015
 Paul Green
Canon Expert
Level 2:
Prodigy:
Answers
527
Questions
Helped
232935
Points
686
If you are closer to your subject than the minimum focus distance of the lens the camera will not focus and therefore will not let you release the shutter.
How do I unhide alarms 2 and 3?
Set multiple alarms. If any alarm is active,(picture of alarm hear) appears in time display A. Press MODE repeatedly until ALARM appears, followed by ALM1. Press STOP/RESET to select Alarm to set. B. Press SET/RECALL to set alarm. HOURS digits will flash. Press +/- to change HOURS. C. Press NEXT and +/- to set MINUTES, AM or PM (if primary time display is in 12-hour format), DAILY, WKDAYS, WKENDS, or day of the week (weekly alarm). D. Press DONE to exit. E. Press +/- to set different Alarm. Set as above. F. In Alarm mode, press START/SPLIT to turn Alarm ON or OFF. TIP: Alarms apply to selected Time Zone of watch display. Backup Alarm sounds after 5 minutes if no button is pressed. Turning off any Alarm or backup will not affect other alarms. http://assets.timex.com/user_guides/W191_M131/W191_M131_NA_EN.pdf
tip
HOW TO TURN OFF THE TRUNK OPEN ALARM
The 2012 Camry's trunk lid has a 'trunk open' alarm that shows up on the instrument panel as 'door open' red icon. It also turns on the door open beeping sound so long as the trunk lid is open. This is normal and is usually not a problem..
However, if you should need to carry a large item in the trunk and can't close the lid, be prepared to listen to the incessant door open sound with no means to turn it off!!
The trunk lid alarm 'switch' is operated by the trunk latch when you open or close the lid. By manually operating the latch to it's closed position, you can temporarily silence the alarm.
Using a small screwdriver, you can easily press the actuator and turn the alarm off.
Picture 1: trunk lid latch in the OPEN (Alarm ON) position.
**WARNING**
YOU MUST RETURN THE ACTUATOR TO THE OPEN POSITION (ABOVE)
(ALARM ON) BEFORE YOU CLOSE THE LID. FAILURE TO DO SO MAY DAMAGE THE LATCHING MECHANISM
**WARNING**
DO THIS WITH THE TRUNK OPEN LEVER OR WITH THE REMOTE TRUNK OPEN BUTTON.
Picture 2: trunk lid latch in the CLOSED (Alarm OFF) position.
IF YOU TRY TO CLOSE THE LID WITH THE LATCH IN THIS POSITION YOU MAY DAMAGE OR BREAK THE LATCHING MECHANISM
Have a 1975 Porshce 911S, with a ungo auto alarm Model TL3000, Serial #11226. Lost my 4 digit number to start car, thanks to my grandkids. So without this, I have to remove system, live in Flint, Mich....
Hi there
The best would be in this case to remove the alarm.Take a picture of the fuse box with the wireing and i will tell you wich wires to remove so the car can run again..
It is also posible the alarm is wired to your ignition system have a look under the ignition and if you can and take a picture of it too.And take a picture of the wires to the batery....
I will help you out...
[email protected]
proporsche
1helpful
How to set alarm in timex t42351 watch
Hi rplokin,
I finally found the user's guide for your timex watch. I am attaching a picture of it, download the picture and view in full size to see how to set an alarm on your watch.
i hope i solved your problem, please vote and rate me.
Regards,
Salman
1helpful
I can't turn the alarm off so that it won't go off daily. Right now it goes off everyday and I don't want it to.
If you click the "alarm" button repeatedly you can pick what you want to wake up to. Do this until the only little picture lit up is the alarm clock picture. That will turn of the alarm.
I cant find the manual so I dont remember how to set the weekday alarm. Also can you show a picture of what the display should look like when the alarm is set? Or describe it? Thank you.
Press the Alarm button. The weekday alarm symbol will appear. Then press and hold the Alarm button for 2 seconds to enter the set mode (the hour will blink). Use the up/down buttons to choose the hour for the alarm (note the A.M./P.M. if in 12 hour mode). Press Alarm again and the minute will blink. Again use the up/down arrows to set the desired time. Press Alarm once more to exit the set mode.
To activate or deactivate the alarm, press the Alarm button until the weekday alarm icon appears. Then use the up/down arrows to activate or deactivate the alarm. When the alarm is set and active, the time will show. If the alarm has been deactivated, then dashes will appear instead of the time.
The single alarm is set and checked similarly.
I hope this helps.
(I suspect that the weekday alarm icon continues to display when the alarm is active.)
Wake up alarm picture coming on in analogue therefore no picture requires dtv button to be pressed on remote control to get digital picture
Rang up Samsung no answer to the problem, model does not allow to pre select digital when setting alarm, thankyou.
24helpful
I CANT GET the alarm clock picture of my screen of my samsung impression
Open the folder (widget) indicated by the arrow on the left of the main screen and drag the Alarm Clock icon into the folder.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
