Lands Phones Logo
A
Anonymous Posted on Mar 11, 2015
Trying to change the time/date
I do feature then **23646 and then the Password box comes up, but when I try and put in the password, nothing happens. Help!
Clyde Manning
Level 1:
New Friend:
  • Contributor 71 Answers
  • Posted on Jul 22, 2015
Clyde Manning
Contributor
Level 1:
New Friend:
Answers
71
Questions
0
Helped
23305
Points
86
Did you try 23646 (admin) for the password too?
5 Related Answers
Anonymous
  • 326 Answers
  • Posted on Apr 18, 2008
SOURCE: Changing Time and Date
i had this problem a while ago, you have to set the time from the main phone
Press FEATURE **8463 – Display shows PASSWORD:
Then type in 23646 (Note this number will not show on display)
The display will show hours.
Press CHANGE (or NEXT if you do not need to change the hour).
Enter the hour (00 to 23). If number is less than 13, the display shows AM.
Press CHANGE to select PM.
Press NEXT. The display shows minutes.
Press CHANGE (or NEXT if you do not need to change the minutes).
Enter the minutes (00 to 59).
Press NEXT. The display shows year.
Press CHANGE (or NEXT if you do not need to change the year).
Enter the last two digits of current year.
Press NEXT. The display shows month.
Press CHANGE (or NEXT if you do not need to change the month).
Enter the month (01 to 12).
Press NEXT. The display shows day.
Press CHANGE.
Enter the day of the month (10 to 31)
Press RLS (release) to exit.
A
Anonymous
  • Posted on Aug 14, 2008
SOURCE: name change on norstar system
try 266344 as the password
Anonymous
  • Posted on Dec 12, 2008
SOURCE: trying to set time
try using password 266344
Anonymous
  • 192 Answers
  • Posted on Apr 25, 2009
SOURCE: i cant seem to programme the meridian m7324 when i
Actually, you have to press the:
-> FEATURE button first
-> then type in * * 2 6 6 3 4 4 (**CONFIG)
-> the password is 2 6 6 3 4 4 (CONFIG) -or- 2 6 3 4 3 (ADMIN)
What are you trying to do in programming?
Just to let you know, once in the programming, and you start to make changes - document the changes.
Because if you change something and your system doesn't work anymore, you then can change the settings back -or- call in a Norstar Technician, you can give that person your notes on what you changed to fix your issue.
Anonymous
  • 105 Answers
  • Posted on Aug 19, 2010
SOURCE: I am trying to change
Try this:
Press "Feature * * 266344"
At the password prompt, press "23646"
This should bring you to the Terminals and Sets menu and you can enter the extension number and change the Set Name.
Good Luck!
HOW DO I CHANGE THE DATE AND TIME ON A NORTEL T7316E
You should complete programming on a T7316, T7316E, M7310, M7324 phone.
1. Feature **23646
2. Password: 266344
>>>Your password may have been changed by your phone company. Contact them for the password.
3. Select General Admin
4. Select Date and Time
5. Select Time
6. Adjust the Hour, Minute, and AM/PM
7. Press Rls when done
Access Denied
Try Feature ** ADMIN (23646) and password 23646. This should let you in to make name and time changes.
I'm trying to change the display names for each extension but when i try the **266344 a user id option pops up....not for a password. What do i do?
Try pressing the FEATURE button then, **266344. On some Norstar phone systems there is also an Admin level of programming that is useful if you only need to change the names or the time. To access Admin programming, press Feature**23646(spells admin on the dial pad). Then 23646 for password.
I am trying to change the names displayed for each intercom number. I tried to access "admin" Feature: ** 23646, however it will not display "password" therefore I am stuck and just end up giving up. ...
Try this:
Good Luck!
2answers
Unable to change the time on the phone
If feature ** 266344 with a password of 266344 didnt work you can also try feature ** 266344 with the password of 23646 or the password of 727587.
Also, on some versions you can try feature **8463(time) with the password of 23646.
1helpful
Norstar 7324 time change
Programming should be done from the M7310, M7324 or the T7316E set. Administration access code: Feature * * 266344 which also is Feature * * config.
If asked for a password enter 23646.
When in programming2.gif just press the next button(lower right arrow) until you see what you want to change. Then press show ( top right arrow) ,then change if you want to change it. If you pass it, just press back (lower left)
Example: To change the Time & Date Press next until you see Time & Date. Then show Then change Then change again, change it if you need to, Then next again until you see what you need to change. For example; only the hour needs to be changed for day light savings time. Just press next until you come to the Hour. Then Change it. Then press release RLs when your done.
2answers
I cant seem to programme the meridian m7324 when i put in the password **23646 it does nothing it wont even go to the password bit just freezes and does feature time out , i cant change the names or the...
I think you need to enter the password **266344 (CONFIG) first, then **23646 (ADMIN). The first is the password that gets you into programming mode and the second is the password for the programming level you want.
2helpful
2answers
Re-set date and time on display
Have you tried:
Feature **23646 password 23646 (if you phone admin hasn't changed this) and then select set day& time then change there
Change display information
2answers
Time Change
have you tried using the password:
23646
Top NorStar Lands Phones Experts
Paul Bade
Daniel Blask
Daniel Blask
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
